Sony Vegas to AAF file?
Posted by Philip Helander on December 19, 2015 at 1:52 pmHi!
Me and my brother have made a shortfilm, we have edited it in Sony Vegas Pro 13. Now another guy is going to do a soundmix for us. He wants an AAF file.
I don’t really know how that works. I have tried to export it in both Pro Tools aaf and mediacomposer aaf files. All that happens is that all the files gets copied to a folder in their original format. I don’t even get a file thats named .aaf.
Can someone explain this to me? Am I supposed to get one aaf file or just all the other files copied? How does this work?
Atentaten replied 10 years, 8 months ago 3 Members · 6 Replies -
Aaron Star
December 20, 2015 at 9:24 amI just tried in VP13 File>Export>Pro Tools AAF, and I get the source files copied and an .aaf file. Not sure why your getting the same thing or is not be working.
Depending on your audio track layout, MXF codecs like XAVC, HDCAM, XDCAM have the ability to pass multiple individual tracks along side the video.
If you have the AVID codecs installed, you can render to DNxHD.MOV and that will support 32 channels. Pro tools should understand that format.
XDCAM has 16 mono channels
HDCAM has 24 mono channels
XAVC has 8 mono channels
WMA Pro supports 7.1You have to get pretty intimate with multi channel audio in Vegas, and bus mapping to the channels you want.
In the end, you may need to just provide an ProTools compatible video file, and then a wav file for each audio track you want to keep separated. That will get the guy working.
Philip Helander
December 21, 2015 at 8:04 amI checked the log and when I try to export my project to an AAF file, it’s starts to load and copy all the files, and then it says it failed and see log for details.
At the end of the log I get this message that I don’t understand at all.
Unexpected problem: System.Exception: AppendClipToTrack failed(error code: 0x8012016C )
Any ideas?
Aaron Star
December 21, 2015 at 4:56 pmHave you run all windows updates, including optional one having to do with .NET?
Are you on the latest version of Vegas 13-64bit (453)?
If you have to install updates or Vegas updates, run Ccleaner both cleaner mode and reg cleanup, then reboot. Then install any updates and reboot before trying export again.
You do have both audio and video tracks in your project, right?
Philip Helander
December 28, 2015 at 3:08 pmYes, I have the latest version and yes, it is both sound and video. I’ve tried it on two computers and it’s still nothing that works.
The only thing that does work is if I make a quick small project with some videos and music, then I can export it to an AAF file, it seems to be something wrong with the real main project itself…
I have edited the program in Vegas Pro 11 and now I have to open it with Pro 13 because Pro 11 doesnt export AAF? Right?
Aaron Star
December 28, 2015 at 7:59 pmThat’s a tough one to troubleshoot. I would open the project in VP13 and Save As to an new file, then Mute or delete tracks one by one until the project exports successfully. Once you can determine the offending track, you can look at the details. Vegas and especially the export functions are not tested like “MS Word”, the export function is probably tested by one guy in a cube somewhere. While the test matrix with all the different software versions, codecs, and plugins is huge.
Atentaten
January 3, 2016 at 12:15 pmWhen you export to AAF for protools, do not include video tracks.
You can make a copy of your original veg file, remove the video tracks and export that as AAF.
You can send your audio engineer a separate video file.
