Sony Vegas suddenly taking longer
hello, I’m someone who films speed draws for YouTube, with a Sony Legria r506.I render in 1080p, and my videos are usually 4-7 minutes long, with audio. Using the Internet HD 1080p MainConcept /mp4 format, using “good” as my video rendering quality; without that, my videos are lesser quality.
I am currently trying to render a video that is 4:10 mins. Usually it would take around an hour, however this video will probably take eight, as after two hours of rendering the estimated time left is six hours. I don’t understand; what is causing such an impact?
I have a few reasons on why this might:
• to make my videos, what I do is get all of my recordings, and add velocity, speed them up etc. into one .veg file. There are a lot of recordings; all are 122 GB in size. Then, on my main .veg, I import my .veg file with all my recordings and speed it up even more (before it was around 40 mins long). I then add audio, an outro, flip the video so it is not upside down, then save it as another .veg file. On a new SV window, I import THAT .veg file and then render it. OpenCL is available, but I don’t use it. GPU acceleratino is disabled, and ‘disabled resample’ is selected.
• I do not use any FX, aprt from the pan/crop feature
• Before, I could render a 7 min video in under two hours, with the same profile. However, I did not use the “good” setting, thus it was slightly lesser quality. I do want the ‘good’ qauliy, though.My specs:
Operating System: Windows 10 Home 64-bit (10.0, Build 10240) (10240.th1.150930-1750)
Language: English (Regional Setting: English)
System Manufacturer: To Be Filled By O.E.M.
System Model: To Be Filled By O.E.M.
BIOS: BIOS Date: 12/06/13 00:14:37 Ver: 04.06.05
Processor: AMD FX(tm)-4130 Quad-Core Processor (4 CPUs), ~3.8GHz
Memory: 16384MB RAM
Available OS Memory: 16340MB RAM
Card name: AMD Radeon R9 200 Series (r9 270x, 2gb card)
