Activity Forums VEGAS Pro Sony Vegas Stuck/Freeze at 22% Rendering
  • Sony Vegas Stuck/Freeze at 22% Rendering
    Posted by Augustin Nový on May 21, 2016 at 2:42 pm
    So I wanna render my video which is about 20mins long and whenever I want to render it, it freezes at 22%, Vegas seems to be responding, but the render preview goes black, frame which it was at is now on 0 and if I want to cancell it, it just wont, so I need to terminate the whole Vegas process in task manager. The rendered file is always around 500mb and then it freezes.
    My project consists of 1 video that is cut into 2 parts, 1 image cut into 2 parts, 3 sound files and one is cut into 2 parts and 4 texts.
    Settings :
    https://images.creativecow.net/310441/settings.jpg
    Project Settings : https://images.creativecow.net/310441/project_settings.jpg
    Render Settings :
    https://images.creativecow.net/310441/render_settings.jpg
    My Pc Specs :
    Windows 10 (Pro) 64bit
    Sony Vegas 13 (build 453) Set to admin mode and Windows Vista compatibility
    AMD A8-6660K w/ integrated GPU HD 8570D (768mb)
    8GB RAM
    Lotsa free space on hardrives
    Latest version of GPU drivers, Windows…
    John Lenihan replied 10 years, 3 months ago 4 Members · 3 Replies
  • Eric Dettman
    May 31, 2016 at 8:46 pm
    Does it freeze in the exact same place each time or in a different place?
    Try setting the full resolution rendering quality to “good” in project property settings, as a troubleshooting step.
    Also: Feel free to create a support ticket at the Sony Creative Software portal. We are still supporting the products here during the transition. https://www.sonycreativesoftware.com/myaccount/home?ReturnToView=%2Fcustcenter%2Fask
    MAGIX see.feel.hear.create
  • Andrew Evans
    June 1, 2016 at 9:21 am
    Try turning off GPU acceleration. I had the same issue.
  • John Lenihan
    June 1, 2016 at 4:16 pm
    I get that problem too. Usually when I have incorporated customer provided video with my video.
    I find that if I pre-transcode the customer video, which is usually a different pixel or bit rate into the same as my project, it goes smoother.
    Also, preconvert the audio into 48k sample wave instead of 44k wave or ac3 fixes it.
    john
    John Lenihan
    LeniCam Video Productions
    https://www.lenicamvideoproductions.com
