Activity Forums VEGAS Pro Sony Vegas – still images come out of place when rendering?
  • Sony Vegas – still images come out of place when rendering?
    Posted by Deleted User on January 18, 2014 at 2:14 pm
    When I’m setting key frames for images, it looks perfect in the preview, but when I go to render the video, the output .mp4 file is completely different and all the key framing I have done has all come out of place.. all of the images are about an inch to the left of where the preview showed them.
    How can I fix this problem? This isn’t the first time this has happened, I was working on something a few weeks ago and decided to scrap it because of this problem.
    Stephen Crye replied 12 years, 7 months ago 5 Members · 5 Replies
  • Graham Bernard
    January 18, 2014 at 2:34 pm
    You are describing such an unusual result that I have to think it’s purely a local issue, and/or your Timeline.
    If this was happening for the rest of us, we’d be hearing much more of it.
    Grazie
  • Deleted User
    January 18, 2014 at 4:13 pm
    I think it might be something to do with aspect ratios, and my preview being different to my render settings? Do you know anything about it?
  • Steve Rhoden
    January 18, 2014 at 4:17 pm
    Try rendering to a different format apart from MP4.
    Try a quicktime format.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-461-9019
  • John Rofrano
    January 18, 2014 at 4:32 pm
    [Jake Griffiths] “I think it might be something to do with aspect ratios, and my preview being different to my render settings? Do you know anything about it?”
    Yup. If your project is using a different aspect than your render settings you have correctly identified the problem. The solution is simple. Render to the project aspect, or change you project aspect to match your render aspect and redo all of the picture placement.
    Hard lesson learned but if you plan on doing any Track Motion or Pan/Crop you MUST keep your project aspect and render aspect the same.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Stephen Crye
    January 19, 2014 at 8:08 am
    Jake, try right-clicking on the Preview window, verify these settings:
    “Simulate Device Aspect Ratio” and
    “Scale video to fit preview window”
    Scaling can slow down performance but is needed if you have chosen a size “bigger” than the window.
    Simulate Device Aspect Ratio might be causing odd results, but for me it does not hurt anything – perhaps because I make sure my media matches the project (when possible)
    Steve
    Win7 Pro X64 on Dell T7500, MultiTB SATA, 8GB RAM, nVidia Quadro 2000, Vegas 12, 11, 10, 9 DVDA 6.0 & 5.2(build 135) Sony HDR-CX550V, Panasonic GH3 with LUMIX G X VARIO 12-35mm / F2.8 ASPH, LUMIX G X VARIO 35-100mm / F2.8
