Activity Forums VEGAS Pro Sony Vegas – Selecting/Moving multiple volume points?
  • Sony Vegas – Selecting/Moving multiple volume points?
    Posted by James Dinndorf on June 28, 2011 at 12:46 am
    I haven’t been able to find anything on this, but is there an easy way to select and move multiple audio/volume points in an envelope? It’s easy to grab the bar and move a couple together, but I’d like the ability to shift an entire set of points. Just curious.
    -James
    Rob Spratt replied 9 years, 6 months ago 5 Members · 6 Replies
  • Daniel Hughes
    June 28, 2011 at 1:25 am
    Hold CTRL and select all the ones you want to move?
    Something like that!
    Daniel Hughes
    Amateur Writer, Director,
    Director of Photography
    United Kingdom
  • Mike Kujbida
    June 28, 2011 at 2:12 am
    Select the “Envelope Edit Tool” (toolbar icon, also found under the Edit menu), drag over the desired points to highlight them and then move as desired.
    Holding down the Alt key while doing this ensures that they will move in a horizontal direction only.
    Remember to switch back to the Normal Edit Tool when you’re done.
  • James Dinndorf
    June 28, 2011 at 2:41 am
    Thanks SO much!
  • Mike Kujbida
    June 28, 2011 at 1:42 pm
    You’re very welcome.
    To be honest, I had no idea that this could be done until I started playing with this tool so I learned something new too 🙂
  • Serk Yen
    October 31, 2014 at 3:26 pm
    Is there anyway to select multiple points horizontally?
    Lets say the envelope points go up and down through out the video, I want to select all the low points and set them to be the same, all at once.
    Is this possible?
  • Rob Spratt
    March 13, 2017 at 11:11 am
    6 years later and it was just what I was looking for. Many thanks Mike!
