Activity Forums VEGAS Pro Sony Vegas safe zone for pictures
  • Sony Vegas safe zone for pictures
    Posted by Filip Vondrát on January 19, 2012 at 10:25 am
    Hello.
    I’m trying to do intro for my friend’s youtube videos. And I have problem with safe zone and some invisible safe zone for pictures. I will post picture here:
    As you can see the right box with ? is little bit cut off. It’s because some invisible safe zone of something. I’ve turned off safe zone in options, but it’s still there. I’ve tried to Mainten Aspect output in Pan Crop, but the picture was too big. When I changed the size, it still showed big.
    Thanks for possible answers,
    FW-
    Kris Riley replied 14 years, 4 months ago 2 Members · 3 Replies
  • Kris Riley
    January 19, 2012 at 4:03 pm
    I’m guessing your problem is related to your event pan crop function. If you open up your event pan crop box, you’ll probably see it is clipping your logo. Try moving the bounding box around the logo until you see the clipped portion come back into view. The safe zone doesn’t crop anything or affect your video. It’s mainly used for aligning titles so that they aren’t clipped on old TV sets or broadcast.
  • Filip Vondrát
    January 19, 2012 at 5:30 pm
    Ah I see, you were right. So there is no solution how to put that image on side without making it match output, right?
  • Kris Riley
    January 19, 2012 at 5:37 pm
    If I’m understanding you correctly, you are trying to re size the image without it cropping? You can use Track Motion which is located on the video track itself to re size the image without it cropping. You might want to create a new video track and drag your image up to it. Then use the Track Motion to size it. In the help menu you’ll see what I’m talking about. Look up Track Motion under index. Good luck!
