Activity › Forums › VEGAS Pro › Sony vegas render/preview problem! Quickly.
  • Sony vegas render/preview problem! Quickly.
    Posted by Sami Harmaala on November 9, 2009 at 3:41 pm
    I got this problem and im in a hurry to do this video. (dont care about my bad english)
    Im doing a video where i cut my hand off. I took a shot of my hand being on the table, then a shot of the knife hitting the table. Then i composite those two together and mask that it looks fine and smooth. It looks perfect in preview window:
    But horrible when rendered:
    When i play it on fullscreen ON sony vegas it looks the same as rendered, horrible. How can i fix this?
    These are my project properties:
    Template: PAL DV (720×576; 25,000 fps)
    Field order: Lower field first
    pixel aspect ratio: 1,0926 (PAL dv)
    Frame rate: 25.000 (PAL)
    Pixel format: 8-bit ( if i change this it looks bad)
    Full resolution rendering quality: Preview
    Motion blur type: gaussian
    Deinterlace method: interpolate fields
    Adjust source media to better match project or render settings: Checked
    And my preview properties:
    Simulate device aspect ratio: checked
    Scale video to fit preview window: checked
    Adjust size and quality for optimal playback: Checked
    And as you can see, the project and preview resolution are the same:
    Please help me!
    Theo Van laar replied 16 years, 10 months ago 2 Members · 1 Reply
  • Theo Van laar
    November 11, 2009 at 12:28 pm
    This is what I also have seen before. If you set the mask while the preview is set to a low quality, the results are different for the rendered version. The solution could be to set the preview quality to BEST FULL and not to automatic as you have done
    Theo
