Activity Forums VEGAS Pro Sony vegas render/preview problem! Quickly.
  • Sony vegas render/preview problem! Quickly.
    Posted by Sami Harmaala on November 9, 2009 at 4:07 pm
    I have a problem with preview/render. I am in a hurry to make this video so please reply quickly. (sorry my bad english)
    So, im editing a video where i cut a hand off. I took a shot of my hand laying in the table. Then a shot where a knife hits the table and composited those two together and masked that it looked smooth and good. In preview window it looked perfect:
    But when rendered, it looked horrible:
    When i look the video in fullscreen IN sony vegas, it looks as bad as rendered one: horrible.
    Heres my project properties:
    And as you can see, the project and preview resolution are the same.
    And here is my preview properties:
    So how can i fix this? Please somebody help!
    Sami Harmaala replied 16 years, 9 months ago 2 Members · 8 Replies
  • 8 Replies
  • Danny Hays
    November 9, 2009 at 5:54 pm
    Render it to a progressive format. It looks like very visable interlacing. Hope this helps. Danny
  • Sami Harmaala
    November 9, 2009 at 6:44 pm
    How i do that? Im not very professional. Not so amateur either. But anyways, thanks for a quick reply!
  • Sami Harmaala
    November 9, 2009 at 7:44 pm
    Rendering to wmv did not help. Any other solution? I need this to work.
  • Danny Hays
    November 9, 2009 at 8:06 pm
    Try setting your project properties to progressive and blend fields.
  • Sami Harmaala
    November 9, 2009 at 8:08 pm
    Does not help 🙁 I cant understand what is the problem.
  • Danny Hays
    November 9, 2009 at 8:10 pm
    Thats field order, progressive.
    De-interlace method, blend, with slow moving video, interpolate with fast.
  • Danny Hays
    November 9, 2009 at 10:00 pm
    The picture shows the knife moving fast. Your project settings are set to lower fields and not progressive. that means you’r seeing the lower fields and by the time it scans the upper fields the knife has moved. Setting it to progressive and blend will fix it some but make it blurry. Interpolate will be clearer but may be a little choppy.
  • Sami Harmaala
    November 10, 2009 at 1:23 pm
    Doesn’t help.. Im so frustrated with this.
