Activity Forums VEGAS Pro Sony Vegas Rendering/Effects Problem
  • Sony Vegas Rendering/Effects Problem
    Posted by Jessie Lim on January 22, 2012 at 3:37 pm
    Using Vegas Pro 11, I tried to render my video. My video is video fx-heavy. However, after rendering, there were many glitches in my effects (the clip’s on cookie cutter but it alternates quickly between cookie cutter and the normal clip) and I’m hoping someone is able to help me with that problem. Thank you.
    Laura Newell replied 14 years, 5 months ago 5 Members · 8 Replies
  • 8 Replies
  • Steve Rhoden
    January 22, 2012 at 6:21 pm
    The solution i found for this is simply when you have
    finished editing, you close Vegas,
    open up again, load back your project and render out.
    Steve Rhoden
    (Cow Leader)
    Film Maker
    Filmex Creative Media.
    1-876-832-4956
    https://filmex-creative-media.blogspot.com/
  • Lance Bachelder
    January 23, 2012 at 7:45 am
    Also since your project is effects heavy maybe switch project to 32 bit Floating Point (video levels) in properties just for the render – quality will go way up. Make sure render is set to Best also.
    Lance Bachelder
    Writer, Editor, Director
    Irvine, California
  • Jessie Lim
    January 23, 2012 at 2:21 pm
    I’ve done that but now Vegas just crashes.
  • Lance Bachelder
    January 23, 2012 at 7:47 pm
    What codec/setting are you rendering to? You can also go into preferences and change try reducing the number of render threads.
    Lance Bachelder
    Irvine, California
  • Joe Campbell
    January 25, 2012 at 4:47 pm
    Can you tell me what 32 bit floating is. I am not having any issues right now I am just curious.
  • Lance Bachelder
    January 26, 2012 at 9:12 am
    Sorry for late response – just spotted this. Vegas works in 8 bit color space by default. This fine for most work as most cameras capture in 8 bit and most delivery and broadcast formats are also 8 bit. But when it comes time to color correct your show or ad certain effects like blurs etc it helps to have the extra math to create high quality results with minimal artifacts and banding etc. Vegas allows you to switch your show into 32bit mode when it comes time to add the finishing touches and render. The results can be significantly better even if you render back to an 8 bit final product. If you are working with 10bit material you’ll definitely want to turn 32bit for your final render.
    Other NLE’s like Premiere Pro and FCPX work in this floating point space to achieve better results. Programs like After Effects and DaVinci Resolve also allow you to work in 32 bit. Go the Vegas Pro help index and type 32bit for more detailed info.
    Lance Bachelder
    Irvine, California
  • Jessie Lim
    January 30, 2012 at 12:20 pm
    Tried reducing the number of render threads but it still doesn’t work
    My codec is:
    wmv 6Mbps HD 720-30p
    Video Smoothness- 100
    Video rendering quality- Best
    I really appreciate you taking time to help me out 🙂
  • Laura Newell
    April 13, 2012 at 8:16 pm
    i have similar/same problem 4 years ,tryed many diff windows versions,32 bit,and 64 bit,diff codecs,diff render and preview setting originally i had effects turn out like in prerender preview ,now not even close 4 example light rayrs,in video itll look perfects size,proption,intensity,wen redered,itll either be 2 strong or too light,or not right size,this happens in almost evry effect,i dont understand why ive even used vegas pro 8,9,10,and 11 over years currently using 10 as thats my fav,ive tried 32 bit, 8 bit,best quality,ect. nothing changes help
