Sony Vegas rendering problem
Posted by Cyan Giger on September 19, 2009 at 9:21 pmI want to set the render quality for youtube to CBR not VBR. When I make a custom template and save the settings of the CBR, it still says VBR 90 in the description box. Not only that, but when changing the frame size(from 720X480 to 1280X 720), the custom frame size doesn’t appear in the description box, either. The bit rate doesn’t change too! Can you help me?
Cyan Giger replied 16 years, 11 months ago 2 Members · 11 Replies -
Cyan Giger
September 26, 2009 at 7:40 pmYou sure? Some sort of short tutorial with pictures,about rendering for youtube videos, would really help.
Mike Kujbida
September 26, 2009 at 8:40 pmWhen you created your custom template, did you give it a different name before you saved it?
If you didn’t do this, then nothing got saved as the default templates CAN’T be over-written. -
Cyan Giger
September 27, 2009 at 8:26 amNope, no bingo. Saved it under a custom template. I need the file size to be a bit smaller so it can load on YouTube faster. Any suggestions?
Mike Kujbida
September 27, 2009 at 12:49 pmAs Jay said, the wording in the description box won’t change when you save a custom template.
If I’m being really fussy about a custom template, I’ll change the wording in this box in addition to a new name.Start a new render, choose this template and then check and make sure that all the desired variables on the video tab did indeed get changed.
Instead of an MPEG-2 render, try mp4 or WMV, both of which YouTube will accept.
Cyan Giger
September 27, 2009 at 4:10 pmThank you very much! Now, what settings should I change to get WMV smaller in filesize, to be posted on YouTube?
Mike Kujbida
September 27, 2009 at 9:57 pmDo the same thing you were trying before and that’s lowering the bitrate.
Keep in mind that lower bitrate = lower quality. -
Cyan Giger
September 28, 2009 at 12:44 amWhat bit rate should I use? Should the bit rate be under ISDN, High speed internet, or Internet/Lan?
Mike Kujbida
September 28, 2009 at 12:55 amI’ve never posted anything to YouTube so I have no idea.
My suggestion would be to use the highest bitrate possible that keeps you under the size limit. -
Cyan Giger
October 2, 2009 at 1:46 amThank you for all your help, but there’s one last problem. The Volume is going down a bit when I render it. How can this be fixed?
