Activity › Forums › VEGAS Pro › Sony Vegas Rendering Issue With Fraps
  • Sony Vegas Rendering Issue With Fraps
    Posted by Rina Davis on February 2, 2020 at 5:25 am
    I just changed hard drives, and Sony Vegas worked fine for me beforehand.
    I use Fraps to record gameplay, and the K-Lite Codec Pack to make Sony Vegas see the .avi files as always.
    However, while the raw videos are perfectly fine, my renders are not now. Everything is horribly pixelated. I have disable resample on too.
    I even ran the MediaInfo tool to make sure my files were matching the project properties and render settings.
    MediaInfo:
    1600×900, 60 FPS
    Rina Davis replied 6 years, 7 months ago 3 Members · 5 Replies
  • Graham Bernard
    February 2, 2020 at 5:56 am
    Sounds like a mess. Why is your Render at 29xx and everything else is 60? Why?
    * Grazie
    PC 10 64-bit 64gb * Intel® Core™i9 – 3.3GHz * 40Gb NVIDIA GeForce RTX 2070
    Cameras: Canon XF300 + PowerShot SX60HS Bridge
  • Rina Davis
    February 2, 2020 at 6:19 am
    Yeah, Sony Vegas and codec problems usually are.
    Not sure. It defaulted to that. I changed it. Same issue.
  • Rina Davis
    February 2, 2020 at 7:21 am
    I just tried to record with the built in game bar with Windows 10 and the same rendering issue happened with Sony Vegas. The very beginning of each clip came out very pixelated.
    Fraps is also saving new recordings with sound only (tried multiple browsers). :\
  • Francois Pénzes
    February 3, 2020 at 10:28 am
    Hi Rina
    K-Lite is notorious for creating problems with editing software. If Make sure after you delete it that nothing is left behind, including in the registry.
    Cheers !
    PC Win 10 Pro 64-bit 16gb
    Ryzen 9 3900X 12 Core 4.60GHz
    Radeon RX 5700 XT
    Cameras: Canon XF305 + Canon XH-A1
    Vegas Pro 16, User since Vegas 3.0
    \’\’When the cutting stops, the editing begins…\’\’
  • Rina Davis
    February 3, 2020 at 6:10 pm
    The problem is I don’t have a codec working. New install. I always used K-Lite no problem. If I don’t use that, I need to use something else that is a codec package.
