Activity › Forums › VEGAS Pro › Sony vegas render problem + quicktime
  • Sony vegas render problem + quicktime
    Posted by Ashley Burns on October 17, 2010 at 1:55 pm
    Why is it whenever I render a video, at 50% it’s rendered the whole video (you can see on the preview window) and then it just renders it again, doubling the render time! Why is it doing this? I’m rendering a HD 720p Main Concept AVC/AAC (.mp4) clip with 10MBPS two-pass and deblocking filter enabled, 25fps…
    Also, whenever I try and import files like .mov or a quicktime related file…it says that quicktime may be broken – i’ve reinstalled, cleaned the registry then installed again but still it doesn’t work, maybe thats causing the double render?
    Roger Bansemer replied 15 years, 11 months ago 3 Members · 2 Replies
  • John Rofrano
    October 17, 2010 at 5:28 pm
    [Ashley Burns] “Why is it whenever I render a video, at 50% it’s rendered the whole video (you can see on the preview window) and then it just renders it again, doubling the render time! Why is it doing this? I’m rendering a HD 720p Main Concept AVC/AAC (.mp4) clip with 10MBPS two-pass and deblocking filter enabled, 25fps…”
    Because that’s what two-pass does. It makes two passes over the entire video. Once to calculate bit-rates and a second time to do the actual render.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Roger Bansemer
    October 18, 2010 at 3:03 pm
    I’m saw the end of my project being rendered in a uncompressed .mov file in the preview window. Then the preview when black but it still has 20% to go on the render time. That last 20% moves at a snales pace at about 2% in the last hour and a half.
    The really bad news is that I haven’t been able to get through it yet as it keeps crashing. I’ve tried 4 times now and all I end up with is an “error occurred” message.
