Activity › Forums › VEGAS Pro › [Sony Vegas Pro] Video does not match Audio
  • Andrew Lenczycki
    July 28, 2015 at 3:05 pm
    I think you have a choice of (at least) two ways to go:
    1) Move each of your events to the left to close the gaps on your timeline, or;
    2) Grab the right edge of each event while holding down the CTRL key. Now “stretch” the event to the right until it touches the next event on the track. This will lengthen the video without looping it. It will also have the effect of slowing down the video.
    Andrew Lenczycki
  • Sebastian Karlsson
    July 28, 2015 at 4:17 pm
    THanks for the reply! 🙂
    The 1st one:
    Can’t really do that. Gotta be like that for it to be good.
    the 2nd one:
    Seems to stretch the sound too :s
  • Danny Hays
    July 28, 2015 at 5:39 pm
    If dragging the edge makes it loop. then that’s the length of the clip. You cant make a clip longer than it really is without looping or stretching as Andrew says. As far as stretching the audio too, the video event and the audio event are grouped, by default in Vegas if both are as one when you added them to the timeline. You can select both with the Ctrl key. With both highlighted, hit the “U” key and it unlocks them and you can change one without changing the other. You can regroup them by selecting both and hitting the “G” key.
  • Steve Rhoden
    July 29, 2015 at 3:29 am
    You are going about this all wrong somehow… You simply need to follow
    the instructions given by Andrew and Danny, its nothing complicated.
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
