Activity Forums VEGAS Pro sony vegas pro 9 slow preview
  • sony vegas pro 9 slow preview
    Posted by Cata Sima on June 19, 2009 at 12:04 pm
    Hi. I`m working with HDV material (1920x1080x30i). the format is .m2ts
    sony vegas works almost fine on best preview quality at the starting of the progect,but later,as the project grows (not adding effects,just cuts), the preview gets annoying,it freezes for a couple of seconds everytime i hit spacebar to play the edited material and it’s not realtime anymore. it doesn’t preview at 30fps.
    what should i do? is it about codecs installed ? i istalled k-lite mega codec pack
    i have 4gig of RAM,intel quad core,2.83ghz,geforce 9800gt 1gb ram….where is the problem ? it’s giving me a whole lot of headaches,it’s wicked.
    Peter Bailey replied 17 years, 1 month ago 3 Members · 3 Replies
  • John Rofrano
    June 19, 2009 at 4:39 pm
    As HD projects get larger they do get a bit slower because they use more memory. I would avoid installing any “cocec packs” like the plague. This could cause applications to respond slowly because you may have replaced a very efficient codec with a very inefficient one. I assume it was slow before you did this so it’s probably not the problem.
    You didn’t say what version of Vegas or what OS you are using. If you have very large HD projects you should be using Vista 64 and Vegas Pro 9.0 64-bit. This will make good use of all of your memory.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Cata Sima
    June 20, 2009 at 8:46 am
    yeah,as a matter of fact,i am using Vista Ultimate x64 sp2 and Sony Vegas pro 9.0 i am really thinking to upgrate to 8GB of RAM,i think that would be a better solution. but still i need to work this out faster and soon.
  • Peter Bailey
    August 15, 2009 at 6:12 pm
    This is a new issue with vegas I have all the same as you technically BUT I have 8gb of ddr 2 ram. I have been having problems with this after the update of vegas pro 9.
    I have made loads of checks on my pc and its running great, i wonder if anyone has reported this to snoy andway here are my pc specs:
    intel q9550 2.8 ocd to 3.2ghz
    cpu at 400 with fsb at 1600
    ocz gold series ddr2 at 400mhz 5,6,6,18 ratio 1:1
    gigabyte p35c-ds3rv2 motherboard
    bfg tech gtx 260 oc max graphics card
    2 x wd raptor 150 gb raid 0
    coolermaster 850 modular psu
    coolit water cooling.
    pioneer blueray writer.
    Focusrite firewire saffire pro 24 audio interface
    edirol monitor speakers front
    creative gigaworks speakers rear
    centre speaker not yet installed
    iiyama prolite e2403ws 24 inch hd monitor
    samsung 2433bw 24 inch hd monitor.
    vegas pro 9
    cinescore
    soundforge 9
    acid pro 7
    sonar 8 pro
    vista ultimate sp2 64 bit
    advice would be helpful on this issue its driving me mad too.
