Sony Vegas Pro 9 – Rendering sped up .mts files
John Rofrano replied 13 years, 10 months ago 2 Members · 31 Replies
John Rofrano
October 25, 2012 at 2:55 pmYou never answered my question:
If you render the footage without changing the speed with velocity envelopes i.e., just drop the raw camera footage on to the timeline of a project using Interpolate Frames and render to Sony AVC using the Internet HD 1080p template, how does the render look? Is it still bad?
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Sander Somma
October 25, 2012 at 4:52 pmSony Vegas 10, it looks good, but dosnt let me change the bitrate to 25.
SOny Vegas 11, errors and dosnt let me render with that template -
John Rofrano
October 25, 2012 at 5:00 pm[Sander Somma] “Sony Vegas 10, it looks good, but dosnt let me change the bitrate to 25.”
So the footage renders fine if you don’t add a velocity envelope. I’d say it’s the velocity change that’s likely causing the problem.
[Sander Somma] “SOny Vegas 11, errors and dosnt let me render with that template”
Do you have any Codec-Paks installed on your PC? (e.g., K-Lite?) You should be getting errors using the standard templates.
~jr
Sander Somma
October 25, 2012 at 5:17 pmNo codecs installed. And it still looks bad when I do it with streching speed up
John Rofrano
October 25, 2012 at 6:38 pm[Sander Somma] “No codecs installed. And it still looks bad when I do it with streching speed up”
If you’re speeding it up, try right-clicking the event and select Disable Resample. That will help if what you are seeing that you don’t like is ghosting.
~jr
Sander Somma
October 25, 2012 at 6:52 pmOH GOD DUDE, Why in the name of science didin’t you tell me that SOONER ????? It works now, seriously. Just as I was about to get it started in premiere, WICH dosnt give me ANY of that shit. Should really change my applications
Sander Somma
October 25, 2012 at 7:26 pmAnd also, Thank you very much. You’ve really helped Me alot out there.
John Rofrano
October 25, 2012 at 10:05 pm[Sander Somma] “OH GOD DUDE, Why in the name of science didn’t you tell me that SOONER ?????”
Yea, it always seems to be the last thing that you try that finally works. 😉
Without seeing what you were seeing it was hard to pinpoint what the problem was. Had you said that there was ghosting I would have immediately said disable resample… but you said it was, “the worst quality” and “still horrid” so you didn’t give me much to go by.
I’m glad we figured it out.
~jr
John Rofrano
October 25, 2012 at 10:07 pm
