Activity › Forums › VEGAS Pro › Sony Vegas Pro 9 Render Problem
  • Sony Vegas Pro 9 Render Problem
    Posted by Pedro Cunha on September 3, 2010 at 5:17 pm
    Hi. I made a fragmovie with 2 minutes. When you arrive at 60% / 70% arises the following problem:
    “An error occurred while fragmovie.avi Creating the media file.
    The system is low on memory. You May Be Able Reduce memory usage by closing other applications ”
    Someone help me? Even starting the computer and doing soon render the error continues.
    John Rofrano replied 16 years ago 3 Members · 11 Replies
  • 11 Replies
  • John Rofrano
    September 3, 2010 at 5:31 pm
    It sounds like you are running low on memory. What operating system are you using? How much memory is in your computer? what version of Vegas are you using? and what is the resolution and codec does your source video files use.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Pedro Cunha
    September 4, 2010 at 10:24 am
    Operating system: Win7
    Memory: 4gb
    Vegas version: Pro 9
    Resolution: HDV 720 (1280×720)
    Frame rate: 29,970 (NTSC)
    Codec: Sony YUV Codec
    Thank you
  • John Rofrano
    September 4, 2010 at 3:31 pm
    Are you using Vegas Pro 9.0e? (you should be) Are you using the 32-bit version of Windows 7 and/or the 32-bit version of Sony Vegas Pro 9.0? This will limit you to only 2GB of memory. Still that should not affect 1280×720 video. Are there any FX around the 60% mark that would consume more memory?
    Also how many cores do you have? 4 cores with only 2GB of memory could cause a problem. If this is the case, try reducing your rendering threads (Options | Preferences | Maximum number of rendering threads) to 2 or 1 and see if that helps.
    ~jr
  • Stephen Mann
    September 4, 2010 at 9:47 pm
    How many disk drives do you have? With one you could easily be running out of TEMP space and Dynamic Memory space.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Pedro Cunha
    September 6, 2010 at 5:55 pm
    ~jr I use the 32bit version of Win7.
    With colour setting that you left me the problem still appeared.
  • Pedro Cunha
    September 6, 2010 at 5:56 pm
    Steve Mann I have 2 disk drives
  • John Rofrano
    September 6, 2010 at 8:36 pm
    That means you are limited to 2GB of memory. What is your RAM preview set to? (Options | Preferences | Video then look under Dynamic RAM Preview max (MB)). Try setting it to zero and see if that helps.
    ~jr
  • Pedro Cunha
    September 7, 2010 at 1:21 pm
    Problem resolved but now came another. I did render in .wmv and appears only the audio and the video disappeared
  • John Rofrano
    September 8, 2010 at 10:27 am
    Are you sure you selected WMV and not WMA? They are right next to each other in the drop-down list and WMA is audio only.
    ~jr
  • Pedro Cunha
    September 8, 2010 at 10:53 am
    Yeah I’m sure jr. I went to check the file and is in .wmv
    This is very strange.
