Activity Forums VEGAS Pro Sony Vegas Pro 9 – arrow key-timeline problem (right)
  • Sony Vegas Pro 9 – arrow key-timeline problem (right)
    Posted by Nik Davis on July 17, 2009 at 1:47 am
    Hey guys, so I have an unusual problem goin’ on here. I use the arrow keyes alot for accurate movement along my timeline like many people do and I’ve never had this issue before.
    When I’m zoomed in on my timeline I’m NOT able to move the slider to the right with the right key …but i AM able to move it to the left with the left key. And the weirdest part is, it allows me to move it to the right only when I’m zoomed out far enough on my timeline.
    I’ve checked my keyboard and there’s nothing wrong with it so highly doubt it’s the keyboard unless I accidentally did something to it. (I have a G15 keyboard btw). I’m thinking I changed something in Vegas by accident but I’ve never encountered this problem before.
    Anyone no whats going on? thanks
    Nik
    Emilio Santero replied 12 years ago 3 Members · 2 Replies
  • Erik Staffanson
    June 23, 2014 at 7:35 pm
    Bump
    I have the EXACT same problem, but a newer version, did you ever get this solved? It has worked smoothly since ever and after a re-installation of my PC this problem started appearing. I can live without this feature, but I would be grateful if someone actually does have a fix for this.
    Erik
  • Emilio Santero
    September 15, 2014 at 11:35 am
    Erik (and everyone else!),
    I had the problem myself and searched for help and found this.
    I’m in Vegas Pro 13.
    If you press Alt when in timeline, it toggles Off/On the frame-by-frame movement in the timeline.
    I must have accidentally pressed it and discovered this.
    Hope it helps someone along the way!
    Emilio
    Il dolce fare tutti.
