Sony Vegas Pro 9 64 bit issues
Posted by Russ Hurley on July 22, 2009 at 4:35 pmi found this on the web – shows how many applications / extensions will not work on 64 bit.
https://www.sony-asia.com/support/resources/en_AP/html/Compatibility/Vista/DISonyPU.html
is it worth it????
Sony Vegas 9 Pro 🙂
Joseph Nailog replied 16 years, 2 months ago 5 Members · 5 Replies -
John Rofrano
July 22, 2009 at 6:06 pmAll that shows is that the Sony Picture Motion Browser software that ships with some Sony cameras doesn’t work on Vista 64.
It says nothing about Sony Vegas Pro which works perfectly fine in Vista 64.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
David Shirey
July 22, 2009 at 9:49 pmAlso since I got the 9.0a update everything has worked fine for me in 64 bit Windows 7, in case anyone searches the forum looking for “64 bit issues”
Russ Hurley
July 22, 2009 at 10:42 pmAnd just to reiterate, these are the updates to 9a:
Notable fixes/changes in Version 9.0a
* If you see incorrect colors with certain large still images, please refer to Microsoft knowledge base article KB963106 for a hotfix.
* Added support for essence markers and title metadata for XDCAM EX clips.
* Added surround audio source decoding to the QuickTime reader.
* Added support for additional YUV formats in AVI reader (HDYC, 2vuy, Y422, YUY2, V422, IYUV, and V210).
* Added support for the AJA Xena LHi and 2K cards. SDI is supported for capture, print to tape, and external monitoring; HDMI is supported for external monitoring only at this time. HDMI monitoring requires an HDMI-to-HDMI connection; DVI-to-HDMI converters are not supported.
* The Device Explorer window can now import video from additional Sony hard-drive-based video devices and camcorders (including the HDR SR1).
* Improved performance of OpenEXR image reading.
* Numerous improvements to RED format support, including native 64-bit reading.
* Numerous localization improvements.
* Numerous enhancements to the Vegas color scheme.
* When device control is not available, the Print-to-Tape Wizard now uses the project ruler format to help determine whether to use drop-frame time codes in the leader and trailer Duration boxes.
* Fixed the Browse button in the Project Recorded Files Folder dialog so it defaults to the project folder instead of My Documents.
* Image Sequence rendering now uses 6-digit file names (instead of a variable number of digits).
* The Project Media window spacing has been improved to show more clips.
* Some scripting enhancements have been implemented (RenderArgs SaveProjectPathLink property).
* The Dynamic RAM Preview max and Maximum number of rendering threads preferences are now nonshared preferences between 32-bit and 64-bit versions running on same (64-bit) OS.
* Fixed an issue using some Generic MIDI controllers that used polyphonic aftertouch.
* Fixed a Video Capture issue that was recreating default capture directory.
* Fixed an undo issue that could occur when Preferences > Display > Automatically hide docking area was enabled.
* Fixed an issue that prevented the Video Preview from updating immediately if the project field order was changed.
* Fixed an issue with incorrect generated media (e.g. Text) settings being used when switching between projects that were created from a common project (using Save As).
* Fixed an issue that could cause incorrect behavior if multiple clips were loaded into the Trimmer from the Vegas Explorer.
* Fixed an issue with Import from Hard Disk Recording Unit where only the first clip would appear in the Project Media window.
* Fixed an issue with Import from Hard Disk Recording Unit with files with discontinuous timestamps.
* Fixed an issue where subclip comments were not being preserved when media was relinked during load.
* Fixed an issue where media comments were not being preserved when media was copied with the project.
* Fixed an issue with supplying time information to some VST plug-ins.
* Fixed an issue where using Apply Non-Real-Time Event FX with the Simple Delay plug-in was not including the effect tail.
* Fixed an issue with Apply Non-Real-Time Event FX using monophonic sources.
* Fixed an issue with tempo-synchronized effects when used with Apply Non-Real-Time Event FX renders.
* Fixed an issue in the MPEG-2 reader that could cause black frames in certain cases.
* Fixed an issue which could cause crashes with Windows Media Video (WMV) content.
* Fixed a freeze that could occur previewing MOV files on an external display via IEEE 1394/DV.
* Fixed an issue that prevented smart rendering from being used when rendering MXF DV to AVI DV.
* Fixed an issue with running out of memory during AVCHD rendering.
* Fixed an issue that could cause the Video Preview to freeze when using IEEE 1394/DV external monitoring.
* Fixed an issue that could cause the frame to turn white when using Best mode, Track Motion, and 32-bit floating point pixel format.
* Fixed an issue that could cause a crash during rendering with certain audio plug-ins.
* Fixed an issue that could cause a crash while opening certain MP3 files.
* Fixed an issue reading certain MP3 metadata.
* Fixed an issue that could cause a freeze when using the Video Preview Split Screen View feature with Clipboard contents.
* Fixed an issue that would not show correct preview during fast forward/fast reverse during HDV capture preview.
* Fixed an issue that could cause incorrect playback with clips from certain Panasonic HDV cameras.
* Fixed slow startup times for users with many FX packages.
* Fixed a rendering freeze when using Acoustic Mirror on a bus.
* Fixed an issue with video event masks not rendering in the correct location.
* Fixed a crash rendering MainConcept AVC with the Two-pass check box selected.
* Fixed a crash that could occur when using Undo while dragging a pan/crop rectangle.
* Fixed live update of Video Preview while changing RED File Format Properties in the 64-bit version of Vegas Pro.
* Fixed a problem reading multichannel audio from RED camera files.
* Fixed a render freeze with certain projects.
* Fixed a crash that could occur when attempting to record if the drive containing your recorded files folder is offline.
* Fixed issues with custom templates in Print to Tape and XDCAM Explorer export.
* Fixed an issue with partial conforms in the XDCAM Explorer.
* Fixed an issue with rendering surround projects to multiple mono files.
* Fixed an issue that prevented stereo render templates from being displayed for 5.1 surround projects.
* Fixed an issue with Center control resetting to 0.0 dB (if it was over 0.0 dB) after moving the pan position.
* Fixed an issue with trying to save 32-bit files as FLAC; we now limit these to 24-bit.
* Fixed an issue that caused other file types to be displayed when All Project and Media Files was selected in the Files of type drop-down list.
* Fixed an issue that prevented .veg files from being displayed in the Import Media dialog under Windows XP.
* Fixed an issue rendering 32-bit floating-point project to DPX format if the project contained levels above full brightness.
* Fixed an issue opening some FLAC files.
* Fixed performance issue reading CineForm media when Video Preview is in set to Half or Quarter size (or Auto when it uses these sizes).
* Fixed an issue with certain large images not scaling correctly (resulting in slightly reduced quality).
* Fixed an issue with the ProType Titler not using character animation if you closed the property page while editing the text.
* Fixed a video resampling (e.g., velocity envelope) issue with certain combinations of source media and project formats when Adjust source media to better match project or render settings is enabled.
* Fixed an issue with event mask feather amount jumping in certain cases while panning across an image.
* Fixed an issue that resulted in very dark levels for certain DPX files.
* Fixed an issue reading XDCAM HD422 proxy files generated with newer deck firmware.
* Fixed a crash that could occur saving a customized keyboard map.
* Fixed an issue that could cause a crash when running the application with the Device Explorer window open and certain optical discs (such as Blu-ray Disc media) loaded.
* Fixed an issue with rendering to AVI using a custom template when the audio format was set to anything other than “uncompressed.”
* Fixed an issue in capture entering timecode when the device’s dropframe/non-dropframe state differs from the previous clip.
* Fixed an issue reading MXF templates from previous versions.
* Fixed an issue with Mixing Console fader positions when switching between automation and trim modes.
* Fixed an issue with the Text generator that caused the Outline and Shadow settings to revert to the default values when turning off the effect.
* Fixed an issue that could prevent the 64-bit version of Vegas from prompting you to save your project when shutting down Windows.New Features in Version 9.0
Video* Support for frame sizes up to 4096×4096 (see the Video tab in Project Properties).
* Support for capturing directly to XDCAM-compatible MXF files from supported SDI sources.
* Vegas can now automatically adjust the video preview size and quality to optimize frame rate during preview.Right-click the Video Preview window and select Adjust Size and Quality for Optimal Playback if you want to emphasize frame rate during preview. When the command is not selected, video quality is emphasized, and the frame rate will be reduced if necessary.
* Select the Adjust source media to better match project or render settings check box on the Video tab of the Project Properties dialog to enable Vegas to make minor changes to your source media properties — including cropping/padding frame size or adjusting interlacing — to allow media files to work better with your project.
* Improved 32-bit, floating-point (video levels) processing mode ensures color level and contrast compatibility with 8-bit mode (see the Video tab in Project Properties).
* Gradient Wipe transition.
* New Glint, Rays, Defocus, Starburst, Soft Contrast, and Fill Light video effects.Audio
* Audio-only edits (such as event moves, trims, and ASR times) are no longer quantized to frame boundaries by default when Quantize to Frames is enabled. If you want to quantize audio-only edits, clear the Do not quantize to frames for audio-only edits check box on the Preferences > Editing tab.
* Audio-waveform drawing during recording has been improved:
o Recorded waveforms are now updated at a faster rate.
o 16-bit peak files are used for increased resolution.
o The entire waveform is now visible during recording.
o Peaks no longer need to be built when recording is completed.
* A Use all Streams and Channels command has been added to the Trimmer window shortcut menu to allow you to choose how streams and channels are handled when adding media to the timeline.Workflow
* The Vegas interface uses a new, darker color palette that’s easy on your eyes when working in a darkened editing booth.
* Vegas includes new default window layouts.
* The Device Explorer window allows you to import video from AVCHD and XDCAM EX cameras.
* In the Save As dialog, the Copy media with project radio button now copies only media files that are saved outside of the project folder; media files in folders below the project folder are no longer copied.
* In the Video Media Generators dialog, you can now click the Match Event Length button to set the length of the generated media to match the length of the event.
* Hold Alt+Shift while dragging inside an event to slip-trim the right edge of an event.
* Hold Ctrl+Alt+Shift while clicking an event to split it. You can then drag from that point to trim the event in the direction you drag (eraser mode).
* You can now slip all of an event’s takes when slipping an event (choose Slip All Takes from the Options menu).
* You can hold Ctrl (or hold the right mouse button) for fine control while adjusting the sustain portion of event envelopes.
* Time selection envelope editing (adjusts multiple envelope points within a time selection for quick audio ducking).
* Muted events on muted tracks are now darkened on the timeline to indicate their muted state.
* You can now set default fade and keyframe types on the External Control & Automation tab in the Preferences dialog.
* You can now choose to automatically crop still images to match your project’s output aspect ratio.
* In the Render As dialog, templates that match your project settings (frame size, pixel aspect ratio, and frame rate) are displayed with an = symbol in the Template drop-down list.
* Holding the Shift key while dragging now enables snapping if Enable Snapping is turned off.
* When you drag a group of selected events, the first and last event now snap to other snap points on the timeline.
* Pressing ` (grave accent) no longer restores track height for tracks that were previously minimized.Formats
* Native XDCAM EX reading and import.
* Improved support for still-image formats:
o Added support for gigapixel-resolution images.
o Improved performance when working with high-resolution still formats.
o You can now create still-image sequences from the Render As dialog.
o Added support for reading and saving DPX, OpenEXR, and MS HD Photo formats.
* Support for opening and editing RED ONE™ (.r3d) files on the timeline.
* Updated Sony AVC rendering templates for Internet distribution.Sony Vegas 9 Pro 🙂
Norman Willis
July 22, 2009 at 11:29 pmVP9 is working fine for me on V64U.
Cineform is still having problems, but that appears to be my machine.
I could not get 8 or 8.1 to run stable, but 9 is going great.
Norman Willis
http://www.nazareneisrael.org
servant@nazareneisrael.org -
Joseph Nailog
July 23, 2010 at 11:57 pmRendering a 43 sec. AVCHD (MTS File) Clip 1920×1080 29.970 interlaced in Sony Vegas Pro 9 64 bit. Rendering time to complete 2hrs +. How long? Still have Vegas 8.0c (build 260) in same PC. Same clip, same render settings. Completed rendering in less than 1 minute? Is their some settings in Pro 9 I need to check or uncheck? Any thoughts?
My Editing System:
-Gateway model FX6800 (i7 9200)
-12GB RAM
-Windows 7 (6.01.7600)
-Vegas Pro 9.0d (build 1132) 64 bit
-Vegas Pro 8.0c (build 260) 32 bit
