Activity Forums VEGAS Pro sony vegas pro 9 32bit on a 64bit system?
  • Mark Greenwood
    May 6, 2010 at 6:24 am
    Yes you can – in fact you can have both the 32 and 64 bit versions side by side…
    Note that if you use certain video codecs and FX in 32 bit and then try and open them in the 64bit version they might not work – because some codecs (for example Camtasia) don’t have a 64 bit version – otherwise your generally ok…..
  • Prateek Richardson
    November 30, 2010 at 7:05 am
    i am not able to install sony vegas pro 9 on windows 7 64 bit,,pls any one can help me??thanx in advance
