Sony Vegas Pro 8.0 will not open mp4 files?
Posted by Katey Jones on April 18, 2011 at 10:08 pmI tried to drag an mp4 video into Sony Vegas and all it gave me was the audio.
I’ve looked around but no other solutions seem to work for me. And I was going to convert it using Xilisoft HD Converter, but it told me it would take up to seven hours.
Is there any kind of codec that I’m missing that might work? :\
Matthew Jeschke replied 15 years, 5 months ago 4 Members · 4 Replies -
Matthew Jeschke
April 18, 2011 at 10:27 pmI have 10. It opens them fine but they are so highly compressed that it doesn’t work well with them.
I suggest finding a converter and making them a wmv or avi. Something more manageable to work with. I think there’s software out there thought that will convert to a different format on its own. I just re-render as vegas 10 supports most formats but performance isn’t the best when cutting them.
My two cents… I don’t think supporting so many different formats directly in timeline is the best approach. I’ve seen things glitch in 10 not to mention it bogs the computer down dramatically. Although I must say it is nice to be able to bring them in. Just wish it had option to standardize them all to a single easy to use format.
Stephen Mann
April 19, 2011 at 4:12 amIf multiple formats bogs down your computer, then you need a new computer.
Steve Mann
MannMade Digital Video
http://www.mmdv.com -
John Rofrano
April 19, 2011 at 1:46 pm[Katey Jones] “Is there any kind of codec that I’m missing that might work? :”
Motion-JPEG with PCM audio should edit easily in Vegas Pro 8.0 and maintain high quality. You can use AviDemux 2.5 to do the conversion. Here are the settings to use:
You might want to try it on a few files and see. I’m pretty sure that 8.0 has an M-JPEG decoder (I know 9 and 10 does).~jr
http://www.johnrofrano.com
http://www.vasst.com -
Matthew Jeschke
April 19, 2011 at 10:03 pmYeah I totally agree. I need a better computer (I’m cutting on an old server my work gave me and a bare bones laptop computer eeek!). I’m on such a tight budget it’s embarrassing to admit. However, I’ve found I can limp by quite well as long as the files are in a format with relatively low compression such as avi.
Are you guys developers? I’ve got a lot of excellent help from you all if you were local I’d make sure to get you a beer sometime!
