Activity › Forums › VEGAS Pro › [Sony Vegas Pro 13 ] Video quality degrades upon import?
  • [Sony Vegas Pro 13 ] Video quality degrades upon import?
    Posted by John Wong on April 25, 2015 at 10:30 am
    Hello everyone,
    When I import this AVI file into SVP13 and render it, I get these random artefacts and some other signs of quality degradation:
    https://666kb.com/i/cy32jw5kuqq4ykdh3.png
    At first I thought this was introduce while rendering, but when I import the video and do nothing with, playing it in the preview window, I get the exact same artefacts:
    https://666kb.com/i/cy32jrlhxjr8wtc8n.png
    The original video’s quality is fine, but as soon as I import it into SVP13, the quality drops. I thought Sony Vegas was non-destructive?
    John Wong replied 11 years, 5 months ago 5 Members · 6 Replies
  • Graham Bernard
    April 25, 2015 at 2:38 pm
    What is the original resolution of that video?
    G
  • John Wong
    April 25, 2015 at 2:42 pm
    The original resolution is 1920×1080.
  • Steve Rhoden
    April 25, 2015 at 9:25 pm
    I assume you captured this via a game recording device?
    If so, these game capture devices don’t capture video content that
    is edit friendly at all, And will pose the same issue you are now
    having with any NLE you use.
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • Aaron Star
    April 26, 2015 at 1:21 am
    In the past I have done screen captures using MS Encoder 4 – Screen Capture” on a 2nd monitor. These files can be opened in Vegas, and then converted to XDCAM or some other format for editing.
    Other times I used a 2nd computer capable of running something like a Blackmagic shuttle or Pcie capture card. Then use the Blackmagic capture tool to capture to uncompressed, or MJPEG. Connect the 2nd or 3 monitor connector from your gaming PC to the Blackmagic car, select clone monitor, and set to 1080p. Then on the 2nd PC, configure the Blackmagic software to capture the HD signal. MJPEG will edit well in Vegas, and the 2nd PC means you are not limiting the game FPS with capture load.
  • John Rofrano
    April 26, 2015 at 12:15 pm
    It looks like a codec problem. What codec does the video file use? (you can use a free tool like MediaInfo to find out) I assume it’s a codec that Vegas Pro doesn’t edit well and you’re going to ned to transcode the footage to something that’s edit friendly before you can edit it.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • John Wong
    April 26, 2015 at 12:18 pm
    Thanks for the replies everyone!
    I fixed it by recording WMV instead of AVI. I’d prefer AVI, but WMV doesn’t seem to have any of the issues AVI has. The code is the Fast MPEG-2 Version 2 Code just in case you’re curious.
