Sony Vegas Pro 13 .avi audio problem
So first off I’ve been using Sony Vegas Pro 13 for at least a year on my laptop to render Dxtory video footage with 2 audio tracks. I recently got a new computer and installed the same version of Vegas on it. At first Vegas would crash when I tried to import an avi from Dxtory. I fixed that by switching aviplug.dll with one I downloaded.
So now I can import them and the video plays fine but the audio on both tracks doesn’t work. It isn’t completely silent about every 8 seconds I get maybe 1 second of audio which sounds perfectly fine. I have searched and searched and I can’t find anything relevant that will fix my current issue. The weirdest thing about this is that I have since tried importing an avi on my laptop which this has worked on for about a year and now it seems to have the same problem as my new computer. I would say this was a good thing since it potentially narrows down what the issue might be but nothing has come to light so far.
I know I could use different software to record or I could convert the file I have now but I don’t particularly want to go there until I feel like I’ve tried everything I can so if you’re just going to tell me to do one of those things then you don’t need to. I’m solely interested in a fix for this specific issue if one exists.
Thanks.
General
Complete name : E:Raw VideoDroid4X 2016-01-16 02-56-33-022.avi
Format : AVI
Format/Info : Audio Video Interleave
Format profile : OpenDML
File size : 27.5 GiB
Duration : 22mn 10s
Overall bit rate : 178 Mbps
Original source form/Distributed by : Video:Lagarith Lossless Codec Audio0:Speakers (Realtek High Definition Audio) Audio1:Microphone (2- USB Audio CODEC )
Writing application : DxtoryCore ver2.0.0.127Video
Format : Lagarith
Codec ID : LAGS
Duration : 22mn 9s
Bit rate : 175 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 60.000 fps
Color space : RGB
Bit depth : 8 bits
Bits/(Pixel*Frame) : 1.405
Stream size : 27.1 GiB (98%)Audio #1
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : 1
Duration : 22mn 10s
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 244 MiB (1%)
Alignment : Aligned on interleaves
Interleave, duration : 100 ms (6.00 video frames)Audio #2
Format : PCM
Codec ID : 1
Duration : 22mn 10s
Bit depth : 16 bits
