Activity Forums VEGAS Pro Sony vegas pro 12 – video has blurry/pixelated parts after render
  • Sony vegas pro 12 – video has blurry/pixelated parts after render
    Posted by Elliot Fältström on February 19, 2013 at 11:49 pm
    Title basicly explains the issue, the last couple of videos I’ve rendered gets really messed up parts and I really can’t seem to find a solution to this problem, I’ve googled for hours without finding any solutions at all so I decided to ask here for advice.
    Here’s an example of the problem: https://www.youtube.com/watch?v=Ccw661hoBT8 Skip to 2:15 to see to worst part, it happens at random spots throughout the video.
    Here’s my specs:
    16gb ram
    i7 3770
    gtx 670
    I render in 30 fps mp4
    Any help would be very much appreciated!
    Nicholas Tessier replied 12 years, 8 months ago 3 Members · 2 Replies
  • Dave Osbun
    February 20, 2013 at 2:16 pm
    What are your render settings? With that much detail in the video game scene, you’d probably get better results with the render bit rate cranked up to the highest, and i’d also choose two-pass as well. It will increase your render time, but the quality should improve.
    Dave
  • Nicholas Tessier
    December 15, 2013 at 1:41 am
    Will bring this topic back up…You need to go to render settings..I use .mp4 but in the settings there should be something along the lines of “Variable bit rate” and it will be checked off, uncheck that and check “Constant Bit Rate” and set it to 10,000,000. This has happened to me before but this is the solution.
