Activity Forums VEGAS Pro Sony vegas pro 12 startup failure at ‘gpu-accelerated video processing”
  • Sony vegas pro 12 startup failure at ‘gpu-accelerated video processing”
    Posted by Gregory Zuniga on December 14, 2012 at 1:23 am
    My computer is a Hp p6000
    amd phenon II X4 820 Processor 2.80 GHz
    ram 8gb
    64 bit os
    windows 7 home premium
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 12.0 (Build 394) 64-bit
    Problem: Unmanaged Exception (0xc0000005)
    Fault Module: C:Program FilesSonyVegas Pro 12.0vegas120.exe
    Fault Address: 0x0000000000000000
    Fault Offset: 0x0000000000000000
    Fault Process Details
    Process Path: C:Program FilesSonyVegas Pro 12.0vegas120.exe
    Process Version: Version 12.0 (Build 394) 64-bit
    Process Description: Vegas Pro
    Process Image Date: 2012-10-26 (Fri Oct 26) 20:11:42
    Rich Kutnick replied 13 years, 8 months ago 2 Members · 1 Reply
  • Rich Kutnick
    December 14, 2012 at 5:52 pm
    I had the same problem when I upgraded to V11 last year (I am now using V12, BTW). Steve Rhoden suggested that I uninstall V11 and remove ALL plug-ins, VST files and any other files associated with Vegas from my hard drive (I backed them up off-line), as he noted that sometimes they can cause such an anomaly. IT WORKED!! I reinstalled Vegas and ran it before putting back the aforementioned files, and it loaded the first time I ran it. I put back a few of the 3rd party plug-ins at a time (the Sony plug-ins of course installed when I installed V11). Needless to say, V11 continued to boot each time I ran it and I never have had this problem with V12, but perhaps V12 is giving you the same problem that V11 gave me?
    Rich Kutnick
    VIDEO IMPRESSIONS
