Sony Vegas Pro 12 replace audio question
John Rofrano replied 11 years, 2 months ago 4 Members · 17 Replies
John Rofrano
October 1, 2013 at 12:01 am[Stephen Mann] “I right-click the audio event on track B and drop it on the audio event for track A, and the only options are Copy or Move.”
This doesn’t work between events. The behavior is adding “media” as a “take”. You cannot add an “event” as a “take” so dragging an event over another event won’t work, which is why it must be from the explorer where the media lives.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Stephen Mann
October 1, 2013 at 4:32 amWell, I was just trying your directions…(vbg)
Re-read what you said and let me know what I got wrong.
Steve Mann
MannMade Digital Video
http://www.mmdv.com -
John Rofrano
October 1, 2013 at 10:29 am[Stephen Mann] “Re-read what you said and let me know what I got wrong.”
I said:
Right-click and drag the audio file you want to add as a take and drop it on the selected audio event
An audio file is not an event so I don’t see where I explained it wrong. Events are things on the timeline. Files are thing in the file system. What confused you?
~jr
Stephen Mann
October 1, 2013 at 1:20 pmOK-got it.
I missed the “file” in this line:Right-click and drag the audio file you want to add as a take and drop it on the selected audio event
So, your instructions are correct – I was reading too fast.
BTW – your solution does work from Windows Explorer as well.
Steve Mann
John Rofrano
October 1, 2013 at 9:52 pm[Stephen Mann] “So, your instructions are correct – I was reading too fast.”
Don’t feel bad I do that all the time.
[Stephen Mann] “BTW – your solution does work from Windows Explorer as well.”
Glad to hear that. I wasn’t sure and I couldn’t test it because I was running Vegas Pro on my Mac in Unity mode under Fusion so I didn’t have a “windows explorer” to test with. 😉
~jr
Darryl Mast
June 14, 2015 at 1:21 pmI hit remove audio for cd button need to rebuild the peaks and put the audio picture back on the pro. How do I do that?
John Rofrano
June 15, 2015 at 12:24 pmYou should probably start a new post and explain step by step what your problem is. I really can’t understand what you are asking from that one sentence.
~jr
