Activity › Forums › VEGAS Pro › Sony Vegas Pro 12 Render Issue
  • Sony Vegas Pro 12 Render Issue
    Posted by John Jorgenson on September 27, 2013 at 12:10 am
    Sony Vegas Pro 12 Build 367 64-bit
    I am having an issue trying to render using the MainConcept ACV/AAC setting. I am using the internet HD 1080p and have only changed the bit rate to be a hair lower. The issue is once rendered the video looks great but every so often I get moments where the video goes fuzzy like a blurry effect then back to normal. I tried changing the template back to normal and it’s the same. I tried looking up info in it but found nothing. In case this is needed my pc info: i7 3930k at 4.3, x2 gtx 680’s 4gb, 16gb ram, asus rampage iv formula board, ssd drives. If any other info is needed please let me know.
    John Rofrano replied 12 years, 12 months ago 3 Members · 9 Replies
  • 9 Replies
  • Steve Rhoden
    September 27, 2013 at 1:03 am
    I too get that sometimes John. Use the Sony AVC format with
    the Internet template instead.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-461-9019
  • Steve Rhoden
    September 27, 2013 at 1:10 am
    Oh, as a reminder, there is a recent Vegas update (Build 714)
    Steve Rhoden
    (Cow Leader)
    1-876-461-9019
  • John Jorgenson
    September 27, 2013 at 1:12 am
    I don’t have that option under Sony AVC.
  • Steve Rhoden
    September 27, 2013 at 3:56 am
    What option are you referring to?
    Almost all the option that is in Mainconcept AVC is in Sony AVC,
    except for maybe 2 pass and deblocking etc.
    If its another option, there is no need to fuss with it.
    Steve Rhoden
    (Cow Leader)
    1-876-461-9019
  • John Rofrano
    September 27, 2013 at 10:22 am
    [Steve Rhoden] ” What option are you referring to?”
    He may be refering to the fact that the “Internet” templates were moved from Sony AVC to MainConcept AVC so they don’t show up under Sony anymore. I have two under Sony AVC but I’m not sure when they got put back and he’s on an earlier build.
    John, Try updating to build 710.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Steve Rhoden
    September 27, 2013 at 11:13 am
    Could be John….I highlighted to him of the recent Vegas update.
    Steve Rhoden
    (Cow Leader)
    1-876-461-9019
  • John Jorgenson
    September 29, 2013 at 5:06 am
    I ended up trying the memory stick template then changing the settings within and it’s the same settings. Just rendered a video and wow was the time so much faster. 45 minute video in 1080 in under 30 minutes and the quality is perfect. No issues at all. I am very surprised I have always used the wmv setting and thought the quality was good. Issue was trying to watch it on full screen in youtube the quality was not a true hd. Now with these new settings the quality is perfect and the render times are cut down by a 1/3. Thanks for the help fellas.
  • Steve Rhoden
    September 29, 2013 at 12:28 pm
    Great!
    Steve Rhoden
    (Cow Leader)
    1-876-461-9019
  • John Rofrano
    September 29, 2013 at 12:45 pm
    Yea, I would avoid WMV for any Internet video. Use AVC/H.264 (either Sony or MainConcept) for low bit-rate high quality video.
    ~jr
