Sony Vegas Pro 12 Not Opening Project
Posted by Rina Davis on October 30, 2014 at 12:21 amI have a few projects that start to open, but the moment Sony Vegas loads the entire program crashes and has to close. Any suggestions?
John Rofrano replied 11 years, 11 months ago 2 Members · 3 Replies -
John Rofrano
October 31, 2014 at 2:12 am[Rina Sims] “I have a few projects that start to open, but the moment Sony Vegas loads the entire program crashes and has to close. Any suggestions?”
Usually this is caused by bad media. Try moving all of your media to a different folder. Then when Vegas prompts you for where the media is, point it to the first file and ignore the rest and see if the project loads. If it does, save that project under a new name, close and open this new project again, and point to the next file and save. Keep doing this until the project does’t load. The last file you pointed it to is causing the problem.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Rina Davis
October 31, 2014 at 3:13 amYikes. I was afraid of that (have an entire drive of solely media files). Thank you.
John Rofrano
October 31, 2014 at 10:26 am[Rina Sims] “have an entire drive of solely media files”
What you might want to consider doing in the future is creating a separate folder for every project and then just copy in the media files for that project into the folder. It makes it much easier to manage and backup your media that way.
~jr
