Activity Forums VEGAS Pro Sony Vegas Pro 12 Keeps enabling View Transform everytime I open Sony Vegas Program.
  • Sony Vegas Pro 12 Keeps enabling View Transform everytime I open Sony Vegas Program.
    Posted by Jacob Murphy on November 3, 2012 at 12:40 am
    Hello everyone! Hope your day is going swell and all.
    So basically I ran into a problem with Sony Vegas Pro 12.
    It seems to be that everytime I open it up, View Transform always opens to a type called “Aces RRT” no matter what I do, everytime it applies by itself.
    gyazo.com/f65a02a3eef5f201e4d637e01ef4145c
    This is applied in the Project Video Properties.
    gyazo.com/88e1180a93c9bac958ff7668469ab53f
    Everytime I have to turn it off to make the video normal.
    gyazo.com/55a6e9f4f81411cb954bae5d28f6144f
    Please help me figure this out as it is VERY annoying fixing it EVERYTIME!
    Thank you guys and hope you have a ongoing pleasant day.
    -Jacob
    Rich Kutnick replied 13 years, 10 months ago 3 Members · 3 Replies
  • Matt Carlson
    November 3, 2012 at 1:20 am
    Does this happen even with a saved project? I have (and I assume) everyone has the same problem that the default 32 bit transform is always ACES. For me once a project is saved as OFF it remains that way. Also if you are working in 8 bit (and have defaulted that way) there are no separate color space considerations and this will not happen. I always use 32 bit full range so I run in to the ACES default problem and have yet to find a solution… not that it is that big a deal to turn the view transform off at the beginning of a project.
  • Jacob Murphy
    November 3, 2012 at 2:01 am
    Matt,
    This happens regardless everytime no matter what the project is. I’m also running 64-bit Sony Vegas, not 32-bit. But I’m also using 32-bit full range. Just some info you may need.
  • Rich Kutnick
    November 7, 2012 at 12:34 pm
    Since I am not familiar with the advantages of 32-bit floating point arithmetic and the view transform options, would you kindly explain the preferred usage and advantages/disadvantages of 32-bit vs. 8-bit processing? Also, when would one use view transform, and which option should be chosen? Too many options sometimes… Thank you in advance.
    Rich Kutnick
    VIDEO IMPRESSIONS
