Activity › Forums › VEGAS Pro › Sony vegas pro 12 has unstable rendering with CUDA and OpenCL.
  • Sony vegas pro 12 has unstable rendering with CUDA and OpenCL.
    Posted by Anders Salvesen on December 2, 2012 at 10:02 am
    Hey.
    I got Vegas pro 12 yesterday, but it seems i have problems with rendering cause of unstable rendering speed.. How come?
    https://www.youtube.com/watch?v=TlYdASIH62g
    Specs:
    i7-3770k
    2x grx 680 4gb
    16gb ddr3 1333mhz
    I render fraps videos from an sata 2.0 samsung spinpoint f3 to an OCZ Agility 3 120gb with 520/500 read/write.
    John Rofrano replied 13 years, 9 months ago 6 Members · 18 Replies
  • 18 Replies
  • Steve Rhoden
    December 2, 2012 at 6:27 pm
    That there maybe your problem. Have you ever used Vegas before to
    complete a render with those same specs?
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-832-4956
  • Mark Barton
    December 2, 2012 at 6:32 pm
    Are you really trying to render video at 128bit per color channel or am I misreading that on your screen? 1920x1080x128
    Is there an option to do something more reasonable for color depth like 12bit?
  • John Rofrano
    December 3, 2012 at 1:23 am
    [anders salvesen] “2x grx 680 4gb”
    Is that meant to be an NVIDIA GTX 680? If so, that’s your problem. Vegas doesn’t yet support the GTX 600 series (Kepler) GPU’s.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Anders Salvesen
    December 3, 2012 at 2:16 am
    Yes, i used to have vegas pro 11, and used to get 6-10 fps with the same render settings as i allways use with only cpu usage cause it did not support the gtx 600 series to render with.
  • Anders Salvesen
    December 3, 2012 at 2:17 am
    It doesnt support 600 series? And still they are at 40 and 60& on both gpu’s when i render wither with cuda or openCL woth no error messages at all like vegas pro 11 would?
  • Anders Salvesen
    December 3, 2012 at 2:28 am
    I saw it now, i have allways rendered at åixel format: 32bit floating point (full range) cause of a youtube video i saw once to have the best quality possible at smallest space taken in my videos since i record gameplay and render fraps videos for youtube, but no matter with my old i5.760 1gen cpu or my new i7-3770k cpu i would allways only have 6-10 fps.. And i dont know why i allways had that poor fps even with 80% cpu.
  • Anders Salvesen
    December 3, 2012 at 4:38 am
    It went much faster with the dept of only 32 aka 8bit ^^
  • John Rofrano
    December 3, 2012 at 11:55 am
    [anders salvesen] ” i have allways rendered at åixel format: 32bit floating point (full range) cause of a youtube video i saw once to have the best quality possible”
    Don’t believe everything you see on YouTube because most of it is wrong. 32-bit is only for people working with 10-bit YUV video which you are not. You should be using 8bit. That’s why it’s the default!
    ~jr
  • Rick Qi
    December 3, 2012 at 1:17 pm
    The default setting is 8-bit just because it requires a weak hardware to work.
    Believe me if you guys tried to improve the scenes by adding several Video FXs, such as color corrector, 32-bit works more perfectly than 8 bit because the former one contains more data after calculation.
    If you guys still do not believe, then try to import an MPEG clip and render it as WMV. Then you will see how 32 full range works more perfectly than the 8 bit!
  • Nigel O’neill
    December 5, 2012 at 12:04 pm
    [Rick Qi] “That’s really shit if compared by Adobe’s.”
    Hey Rick, if you think Adobe is so great, why are you even using Vegas? I moved from Adobe and Avid liquid because it was so unstable, to the point I could not deliver a project or more than 1 occasion. Vegas has never failed me once, and I have done 100’s of projects. Yes, it does occasionally crash, but show me software that doesn’t.
    BTW, all the contributors of this forum are volunteers. Abusive tones and rude language is the fastest way to get alienated and ignored. Maybe it is tolerated in your generation or culture, but here, on this forum, we treat others professionally and with respect.
    [Rick Qi] “The default setting is 8-bit just because it requires a weak hardware to work.”
    As John said, 32-bit is only for people working with 10-bit YUV video which you are not. You should be using 8 bit. This is good advice from a professional who has been working in the business for many years.
