Sony Vegas Pro 12 Frezes When rendering
Posted by Sawyer Porter on July 21, 2013 at 1:05 amSony Vagas pro 12 Frezes when i render my specs are
8 GB of Ram
AMD six core processor
Geforce 660 TiIt ussaly crashes at %75 or higher
Sawyer Porter replied 13 years, 2 months ago 3 Members · 4 Replies -
Steve Rhoden
July 21, 2013 at 7:57 amIts probably caused by one of the video clips you have on
the timeline at that particular spot Sawyer.Steve Rhoden
(Cow Leader)
Film Editor & Compositor.
Filmex Creative Media.
https://www.facebook.com/FilmexCreativeMedia
1-876-832-4956 -
Dave Osbun
July 22, 2013 at 12:48 pmIt could be quite a few different things causing this. First thing i’d check on his system heat. Your CPU is working quite hard when rendering, so maybe it’s getting so hot that it’s causing the system to crash. There are many free utilities that let you monitor CPU heat. Keep an eye on the CPU temp during the render process.
Since GPU render support seems to cause so many issues, you might want to disable it and see if that fixes your issue.
Also- where are you rendering to? System drive? A different hard drive? How much free room is there on the drive you’re rendering to?
Dave
Sawyer Porter
July 22, 2013 at 5:01 pmIm rendering to my desktop and usually i get up to 60-70 for heat
