Activity › Forums › VEGAS Pro › Sony Vegas Pro 12 becomes blurry after uploading to youtube
  • Norman Black
    July 23, 2014 at 5:57 pm
    First, Youtube/Vimeo re-encode everything you upload. If what you upload looks good and the result is not good there is probably nothing you can do. They encode to a somewhat low bitrate and fast detailed motion does not encode/compress well.
    That said,
    You project setting is 23.976 but you are rendering to 29.97. What is up with that? Why are you not rendering to your project setting?
    Personally I would not use x264vfw. Long GOP codecs do not work ideally in AVI containers. I also would not use single pass ABR mode for x264. Your 6Mbps bitrate is lower than Youtube recommends for 1080 uploads. If using x264vfw I would use crf or two pass mode.
    https://support.google.com/youtube/answer/1722171?hl=en
    I would use the Mainconcept AVC or Sony AVC “Internet 1080p” templates and adjust as needed. Your project framerate for example and the audio bitrate maybe. Anywhere is the 10-12Mbps bitrate with the Vegas AVC encoders should probably be good enough for a Youtube re-encode. The Vegas AVC encoders are not as good as x264 but since Youtube is re-encoding just giving the Vegas AVC encoders a little more bitrate is good enough.
  • Steve Rhoden
    July 23, 2014 at 10:15 pm
    Youtube is at fault there, Nothing much you can do.
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • Ziv Anaf
    July 28, 2014 at 4:38 pm
    I tried the “internet 1080p” one
    here is the result
    https://www.youtube.com/watch?v=Qegl_nvWdQA&list=UUqZg75J23pe-pOy0NDvtAMQ
