Activity Forums VEGAS Pro Sony Vegas Pro 11 will not render
  • Sarah Jones
    January 27, 2012 at 12:34 am
    …Okay.
  • Val Murrell
    April 21, 2012 at 7:52 pm
    “Windows Font Cache Service”
    “Windows Presentation Foundation Font Cache 3.0.0”
    that is what worked for me using vegas pro 11
    thanks for the help
  • Ananda Holenarasipura
    May 16, 2013 at 3:46 pm
    Hi Guys,
    I had a very similar problem with pro 12. All of a sudden it started freezing as soon as I hit the “Render as” button. Render window never used to open. I tried reinstalling Pro and restoring the system to an earlier date but nothing worked. I was about to reinstall my Windows OS tomorrow, when I happen to read this thread. Thanks to Sarah, my problem got solved after I disabled the exactly the same two services.
    Infact, I had opened a new thread with my problem a couple of days back in this forum and was waiting for a response. Thanks again for Sarah.
    Ananda
  • David Alfredo
    May 16, 2013 at 10:13 pm
    [Stephen Mann] “Since the Font Cache loads all of your installed fonts in RAM, it denies that RAM from other programs. Some power-users delete fonts they will never use. Also, if the Font Cache service encounters a bad or damaged font file, it may just keep retrying to load the bad font – forever. (High CPU usage and “not responding” are symptoms). (I guess the programmers at MS never thought that you could have a bad font file?)”
    very good observation, this is specially critic if you use Google Chrome before using Vegas, since there’s a Chrome bug if a font is not properly installed or corrupted it would cause high CPU usage (100% load on one core) and weird crashing / issues to whatever software you run after that. I never use Google Chrome when I need to run Vegas, also deleting the fonts cache from time to time does help, very good info.
    files to look for and delete from time to time:
    fontcache3.0.0.0.dat
    fontcache-fontface.dat
    fontcache-system.dat
    usually located in bootdrive :Windows ServiceProfiles LocalService AppData Local
  • Ankita Soni
    March 27, 2014 at 1:08 pm
    i m a user of sony vegas pro 11 it jus doesnt render the project. i did all the above mentioned things.. doesnt work for me. is there any other way out? waiting for a reply.
Page 2 of 2
