Activity Forums VEGAS Pro Sony Vegas Pro 11 Renders all of my MP4 29.97 fps videos as MP4 59.97 regardless of what my settings are.
  • Sony Vegas Pro 11 Renders all of my MP4 29.97 fps videos as MP4 59.97 regardless of what my settings are.
    Posted by Rick Mallars on March 24, 2015 at 4:34 am
    Greetings Vegas gurus! My copy of Sony Vegas Pro 11 Renders all of my MP4 29.97 fps videos as MP4 59.97 regardless of what my settings are. And regardless of what frame rate I shoot in! I used a Sony Nex7 (Video: 00:00:20.020, 29.970 fps progressive, 1440x1080x12, AVC
    Audio: 00:00:20.011, 48,000 Hz, Stereo, AAC)
    I am attempting to render an MP4 using:
    Frame size 1080 p HD (1920 x 1080)
    Profile – Main
    Frame rate 29.97
    Field Order – Upper Field First
    Pixel Aspect Ratio – 1.0
    Constant Bit Rate – 14,000
    Encode Mode – Automatic
    When I render the file (no matter what I change the settings to even if I allow the source to adjust the frame rate or size) it ALWAYS comes out the same – 59 frames per second.
    Can anyone share some ideas on what may be causing this to happen?
    Thanks in advance!
    Rick
    John Rofrano replied 11 years, 6 months ago 2 Members · 3 Replies
