Activity Forums VEGAS Pro Sony Vegas Pro 11 rendering default template? (uncompressed avi)
  • Sony Vegas Pro 11 rendering default template? (uncompressed avi)
    Posted by Ashley Kay on December 20, 2011 at 9:49 pm
    I am using Sony Vegas Pro 11 and I would like to render the profect in the default template which is the uncompressed AVI. How come Sony Vegas Pro 11 doesn’t have this format like the older versions do?
    Joe Mccord replied 11 years, 9 months ago 5 Members · 6 Replies
  • John Rofrano
    December 20, 2011 at 11:05 pm
    [Ashley Kay] “How come Sony Vegas Pro 11 doesn’t have this format like the older versions do?”
    You would have to ask Sony why they made this change. Since using the default template is absolutely the wrong choice 99% of the time, I’m guessing they removed it to reduce support calls. It is very rare that someone would need to render to uncompressed and unless they had a RAID 0 array with a minimum of 5 drives, they shouldn’t even be thinking in these terms for HD work.
    Why do you feel you need uncompressed?
    Why not just create your own template if you absolutely need it?
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Ashley Kay
    December 20, 2011 at 11:25 pm
    I just found it the uncompressed format. What I usually do is I render it uncompressed and compress it using a separate software program.
  • John Rofrano
    December 20, 2011 at 11:36 pm
    [Ashley Kay] “What I usually do is I render it uncompressed and compress it using a separate software program.”
    That’s the 1% where uncompressed makes sense. 😉
    ~jr
  • Matt Clara
    January 4, 2013 at 5:55 pm
    That is so not helpful. You asked a question, other people with the same question perform a Google search and find this post. Then you say, “I found it,” but you don’t say where/how. This thread is officially worthless as a result. If you have a moment, please explain how to render videos to uncompressed AVI format in Vegas Pro 11. Thank you.
  • Mike Kujbida
    January 4, 2013 at 7:51 pm
    Matt, with all due respect, for your very first post on here, you’re not off to a good start.
    This topic (custom render template) has been discussed on here numerous times.
    After you pick the format you want (in this case AVI), click the Custom button and then make the necessary changes in the window that comes up.
    Be sure to save it so that it will come up for future use.
  • Joe Mccord
    December 11, 2014 at 3:51 pm
    Thanks for the helpful info!
