Activity Forums VEGAS Pro Sony Vegas Pro 11 Jarring on Playback
  • Sony Vegas Pro 11 Jarring on Playback
    Posted by Scott Burgess on May 11, 2012 at 7:55 am
    Hi all!
    I’m having an issue with Vegas at the moment, when I’m playing back footage it seems to run okay until there is a cut. It will slow down slightly then lag behind on playing the next shot and speed up to catch it.
    I’ve never had this problem before and I’m running a better system than I’ve had in years. Has anybody had this type of problem before?
    Thanks in advance!
    Scott Burgess replied 14 years, 4 months ago 3 Members · 3 Replies
  • Steven Talley
    May 11, 2012 at 11:54 pm
    Does the rendered video play OK? If its just on the timeline, try setting the playback quality down a notch. If that fixes it you have a bottleneck in your system. Be sure to update drivers for your video card too.
  • Stephen Crye
    May 14, 2012 at 3:19 am
    Run Process Explorer and watch those graphs! Will help id bottlnecks.
    In another post someone passed along a great tip – make sure the preview window is set to not scale. Lately I’ve been using the Preview / quarter setting and it has been able to keep up with most routine effects. However, unless you have a screamingly fast graphics card with a great GPU, you won’t get perfect results in preview.
    To make sure that a section of a vid will render the way you want, select a short section and use the ” selectively prerender” option under Tools.
    Steve
    Win7 Pro X64 on Dell T3400, MultiTB SATA, 8GB RAM, nVidia FX 570, Vegas 10e (and 11) x64 DVDA 5.2(build 133) Sony HDR-CX550V
  • Scott Burgess
    May 14, 2012 at 3:26 am
    Thank you to both of you for your responses.
    I had a bit of a play round and sort of got it working a touch better. I’ve just never experienced that particular jarring when it cuts before. It’s either been completely smooth or equally jumpy throughout the entire playback.
