Activity › Forums › VEGAS Pro › Sony Vegas Pro 10 Render Issue
  • Sony Vegas Pro 10 Render Issue
    Posted by Jānis Bērziņš on July 8, 2011 at 2:43 pm
    Hello!
    So I am having a problem with my Sony Vegas Pro 10. When I render this project it like stops rendering at frame 745, drops down at frame 0 and all you can see in preview screen is black screen, and the percentage of rendering also stays at 12% but the remaining time till end of render is still counting.
    I’ve tried to restart my computer, re-installing Vegas and even upgrading it to the newest version but nothing.
    If it matters then the files in project are in avchd, 1920×1080 and on all of them i have added some color correction, some of them are stabilized and also I have added some animated effects.
    See picture bellow.
    Jānis Bērziņš replied 15 years, 2 months ago 3 Members · 4 Replies
  • Steve Rhoden
    July 8, 2011 at 3:12 pm
    You working with any recently installed plugin added to any
    of the events on the timeline? If so, which plugin is it?
    Steve Rhoden
    (Cow Leader)
    Film Maker
    Filmex Creative Media.
    1-876-832-4956
  • Jānis Bērziņš
    July 8, 2011 at 3:28 pm
    No, I haven’t added any plugins at all.
  • Andrew Lenczycki
    July 8, 2011 at 7:40 pm
    I believe I’ve experienced the same thing in Sony Vegas Pro 7, 8, & 9 (not in 10 – yet). I finally was able to narrow it down by rendering a small amount of time before and after the frame you are snagging on (745). Try rendering while turning off one at a time any special effects used.
    I found that in some instances that being zoomed in and rotated (in the pan-crop tool) and then panning out and rotating back to “zero” caused this type of problem.
    I have also found it happens with some of the FX plugins – the lense flare in particular. I believe that I found with the lense flare FX you can’t run one of the slider values all the way up to 1.0 (on a 0 to 1 scale). If I dialed the value back to .99 the file would render fine.
    The other thing I’ve found is to remove the picture or clip “event” from the timeline, press the purge all files not used button (the lightning bolt) then save the Veg file. Close the file, reopen it and then put the exact same picture or clip “event” back where it was and voila! everything seems to work OK. Not saying that this will fix your problem, but it’s something that you may experiment with to verify the exact “cause” of the problem.
    Andrew Lenczycki
  • Jānis Bērziņš
    July 8, 2011 at 7:52 pm
    Thanks for your advice. I am now rendering my project starting with frame 745 and it is rendering very well so far. It seems that it will make it to the end. Then I will try to render the whole thing again and then I will see.
