Activity Forums VEGAS Pro sony vegas output main concept
  • sony vegas output main concept
    Posted by Martin Bartos on September 12, 2008 at 10:07 am
    hi, can somebody explain me how to render a nice looking smooth and fluent video with vegas 8.0? All the settings I have tried ends up with a video that looks more like a sequence of still pictures than a video… 🙁 I really do not understant it – even an DVD made with architect 4 is same: sharp and not fluent ( I mean the picture and sound are fluent in terms of time, but when looking on a moving object the movement of it doesnt look fine). What should I do?
    Martin Bartos replied 18 years ago 3 Members · 5 Replies
  • Steve Rhoden
    September 12, 2008 at 11:54 am
    You are probably choosing the wrong frame rate in the render
    settings…..
    Further clarify which specific format you want to render out to..etc.
    Steve Rhoden
    Creative Director
    TNX EFFECTS STUDIOS.
    sample bits at
    http://www.youtube.com/hentys
  • Martin Bartos
    September 12, 2008 at 12:10 pm
    i am choosing 25fps for PAL.
    Main Concept MPEG2 / DVD Architect PAL Widescreen video stream / video rendering quality>best / frame rate 25 / format PAL.
  • Steve Rhoden
    September 12, 2008 at 4:06 pm
    Well…If the Original files/footages etc. that you have on the timeline are ‘NTSC 29.97 frame rates’ then that would result in
    the stuttering you are experiencing on final render.
    Steve Rhoden
    Creative Director
    sample bits at
  • Jim Kaye
    September 12, 2008 at 6:04 pm
    Guys, this looks like the same problem I raised in my earlier post ” Rendering Jagged and Mainconcept”. Mine was all NTSC HD. Rendering to any other format but 1080 yields very jagged motion. I’ve tested renders tomultiple formats and with a variety of bit rates and settings with no change. However, If I take a rendered m2t stream and render to NTSC widescreen using Canopus procoder the footage looks great! I really am beginning to believe it is a Vegas 8 or mainconcepts bug. Any others with this issue?
  • Martin Bartos
    September 15, 2008 at 3:44 pm
    well I think Jim is right. My original record is PAL HD and I experienced the same great result in HD m2t output. All the other outputs turns in jagged video. This might be a Vegas bug as my friend told me to convert Vegas output in Premiere and this should solve it. I did not try it, but he did and result was good – by his words…
