Activity Forums VEGAS Pro Sony Vegas on Laptop
  • Sony Vegas on Laptop
    Posted by John Watts on November 20, 2008 at 9:03 pm
    Thinking of getting Sony Vegas Pro and dropping it on an HP laptop with Windows Vista Home Premium 64 with 4gb of Ram.
    Any ideas on how it would perform with primarily DV25 footage?
    How about HDV?
    Haven’t made a firm decision so any input would be great.
    John Watts
    John Watts replied 17 years, 10 months ago 3 Members · 3 Replies
  • Kert
    November 21, 2008 at 5:37 am
    You did not state the speed of your computer. However, the minimum requirement for DV is somewhere around Pentium 2.8 MHz. I actually used Vegas with such computer. With dual core you can easily process HDV. jk
  • Ruben
    November 21, 2008 at 9:08 am
    Hey John K., if you mean the DV codec by DV the minimum requirements for the edit system are much lower than you think they are…years ago i was able to edit MiniDV on a P4 1.5 GHz with Adobe’s Premiere…
    to John W.:
    Vegas is very ressource friendly it just depends on the resolutions you’re working on, HD requires somewhat four times more processing time than standard tv resolutions…an older Pentium M with 2 GHz should help you working on HD as well, but if you can go with a core2duo, do it.
  • John Watts
    November 22, 2008 at 1:37 am
    It’s an Intel Centrino core 2 duo. 4mg ram. Most of the work would be dv25, just interested how it would handle hdv if necessary. It’s also a 64 bit OS.
    Thanks for your help.
    John Watts
