Activity › Forums › VEGAS Pro › Sony Vegas Not Responding!
  • Sony Vegas Not Responding!
    Posted by Austin Rohr on December 29, 2009 at 6:09 am
    Ok so I open up Sony Vegas 8.0 Platinum on my HP running Vista. Everything is good until I try to import any AVCHD media files, this is when the little blue circle comes up and starts rotating. Next I get the Not Responding message and am forced to close the program. No matter what I try have no luck whatsoever. I know it’s a RAM hog to do this but I’ve got pretty decent RAM for a 2.5 year old computer and we were able to run this program with the same footage I am trying to import on his HP desktop. He bought an external hard drive for it but his RAM is the same as mine and all that crud. When this happens I can still run my computer at normal speeds and my RAM doesn’t spike abnormally high plus I already know the program supports the format because it works for my friend AND Sony created AVCHD. Any thoughts at all because I have no solution for this problem and I’m no tech junkie so if this requires lots of tech work then please walk me through it in a dumbed down process. Thanks a lot I’m trying for a YouTube partnership so I really need this to work soon or I will lose my opportunity.
    Austin Rohr replied 16 years, 9 months ago 2 Members · 2 Replies
  • Roger Bansemer
    December 29, 2009 at 12:19 pm
    I’m having the same problem. My project “stopped” working at least 20 times before I could finish it. It never happened when I was using XP but now I’m using Windows7 32bit.
    What’s more I can’t render my project for while trying to make an “architect widescreen mp2”.
    Im thinking it may have something to do with the m2ts files but don’t know. Mine do have a GPS feature built in to the video.
    Here’s a message I get after it stops rendering.
    System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. —> System.ApplicationException: Render failed:
    file name: F:\Saddle_MainConcept MPEG-2_DVD Architect NTSC Widescreen video stream.mpg
    Renderer: MainConcept MPEG-2
    Template: DVD Architect NTSC Widescreen video stream
    Start Time: 00:00:00.00
    Length: 00:26:40.00
    at EntryPoint.DoRender(String filePath, RenderItem renderItem, Timecode start, Timecode length)
    at EntryPoint.DoBatchRender(ArrayList selectedTemplates, String basePath, RenderMode renderMode)
    at EntryPoint.FromVegas(Vegas vegas)
    — End of inner exception stack trace —
    at System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner)
    at System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner)
    at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks)
    at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
    at Sony.Vegas.ScriptHost.ScriptManager.Run(Assembly asm, String className, String methodName)
    at Sony.Vegas.ScriptHost.CodeDomScriptManager.Run()
    at Sony.Vegas.ScriptHost.RunScript(Boolean fCompileOnly)
  • Austin Rohr
    December 29, 2009 at 6:55 pm
    To top it off Sony tech support is terrible!
    This is the message I get:
    Problem Event Name: AppHangB1
    Application Name: VegasMovieStudioPE80.exe
    Application Version: 8.0.0.74
    Application Timestamp: 4641f808
    Hang Signature: 6617
    Hang Type: 0
    OS Version: 6.0.6002.2.2.0.768.3
    Locale ID: 1033
    Additional Hang Signature 1: 91fd09ceb3bd48165f0e1c068ffec979
    Additional Hang Signature 2: 7b70
    Additional Hang Signature 3: 8bd0f7d6faa0d6ed579c0d8b937ae256
    Additional Hang Signature 4: 6617
    Additional Hang Signature 5: 91fd09ceb3bd48165f0e1c068ffec979
    Additional Hang Signature 6: 7b70
    Additional Hang Signature 7: 8bd0f7d6faa0d6ed579c0d8b937ae256
    I’m posting a video to YouTube showing my problem. I hope somebody can help me out on there.
    ~TRX450R/~
