Activity Forums VEGAS Pro Sony Vegas Movie 9 Platinum Pro:: Rendering Issues
  • Sony Vegas Movie 9 Platinum Pro:: Rendering Issues
    Posted by Jerry Broome on January 25, 2009 at 7:05 am
    working on a DVD gift for my brother. Movie is about done. Rendered with what I guess is not the right choice. The movie is soft and the text too.
    Editing in Sony Vegas Platinum 9.0 I would like the end results to be like a high quality DVD. Like I would get at any Blockbusters. I know this is possible. I’m obvious new to this. Would like some help in the rendering aspect of it. Along with helpful suggestions. I read that people render only a small portion of their project to see the results. (I though what I saw on the Pre View is what I’m getting…not) If this is a “check” that I need to but in practice, then what DVD should I use? And forgive me on this…but I don’t want to go through a whole sleeve of DVD’s, can I re-use the DVD I’m checking. ie re rendering on the same DVD.
    Thanks for any helpful advice.
    Captured on JVC Mini DV
    Project Properties::
    Template: NTSC Standard (720×486, 29.97 fps)
    Width: 720
    Height: 486
    Pixel Ration: 0.9091 (NTSC DV)
    Field Order: Lower Field First
    Frame Rate: 29.970 (NTSC)
    Full Resolution Rendering Quality: Best
    Deinterlace Method: Blend Fields
    Audio::
    Master Bus Mode: Stereo (can I do Surround Sound in SVM 9?)
    Sample Rate: 44,100
    Bit Depth: 16
    Resample &Strecth: Best
    Jerry
    John Rofrano replied 17 years, 8 months ago 2 Members · 1 Reply
