Activity › Forums › VEGAS Pro › Sony Vegas media does not render well on native settings?
  • Sony Vegas media does not render well on native settings?
    Posted by Kees Verwijs on May 26, 2013 at 8:54 pm
    Hi all!
    I’ve stumbled across a feature in Sony Vegas Pro which is driving me crazy, so I hope you can help me understand the following:
    When I create & render the letter “A” in Sony Vegas pro in 2 ways:
  • Create in & Render to DVD format (native rendering)
  • Create in & Render to HD format, then re-render to DVD format
  • Completely against my expectations, the second method has a much better quality (much smoother edges). Is this a bug or am I missing something? I’ve posted the result on YouTube (see below).
    Exact Workflow:
    1) Generate Media
  • A single character (“A”)
  • Font color: white, size: 144, type: Arial Black, bold
  • Bump map, intensity 0.150
  • 2) Set Project Settings to HD format
  • Resolution: 1920×1080
  • Field Order: None (Progressive)
  • Pixel Aspect Ratio: 1,0000
  • Frame Rate: 50 (double PAL)
  • Full Resolution Rendering Quality: Best
  • Motion Blur: Gaussian
  • Deinterlace: Interpolate Fields
  • 3) Render to HD format
  • Sony AVC
  • Template: HD 1920×1080-50p
  • (50 fps; 1920×1080 Progressive; YUV; 26 Mbps; Pixel Aspect Ratio 1,000)
  • “Stretch Video to fit output frame size” not checked
  • 4) Add rendered movie (.mp4) to timeline (behind the ‘original’)
  • Add labels showing which clip is which
  • Copy-paste both clips a few times so video flip-flops between the two methods
  • 5) Set Project Settings to DVD format
  • Resolution: 720×576
  • Field Order: Lower First
  • Pixel Aspect Ratio: 1,4568 (PAL DV Widescreen)
  • Frame Rate: 25 (PAL)
  • 6) Render to DVD Settings
  • Type: MainConcept MPEG-2
  • Template: DVD Architect PAL Widescreen Video Stream
  • (25 fps; 720×576 Lower Field First; YUV; 6 Mbps; Pixel Aspect Ratio 1,457)
  • 7) Upload to YouTube
  • The resulting video can be found here (best results when watching at 480p): https://www.youtube.com/watch?v=NxjvXpRaBR4
  • 8) Note: I’ve also burnt the result of step 6) to a DVD and watched on an (interlaced) television. The result was the same: the natively rendered content was much more “blocky” at the edge of the “A” than the Re-rendered clip
    Kees Verwijs replied 13 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
