Activity › Forums › VEGAS Pro › Sony Vegas Loading Problem
  • Sony Vegas Loading Problem
    Posted by Karl Reith on August 19, 2011 at 7:40 am
    Hi guys,
    Haven’t posted in a while, but i’ve run into what seems to be a HUGE problem! It’s prob nothing but hopefully you guys can help!
    I recently re-installed vegas pro 10 and then updated it (without opening any projects) with the Vegas 10e update! Now whenever I try opening a project (“pre” re-installation) vegas comes up with that soul sucking error dialogue saying vegas has stopped working. It loads the project until about 4 or 5% and then crashes.
    Now i got the details of the error report hopefully someone here can figure out what the problem is. I was working on 10e before the re-install and everything worked fine, I have no clue what changed??
    If you guys could help in any way I would be forever gratefull!!
    Here’s the error report:
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 10.0e (Build 738) 64-bit
    Problem: Unmanaged Exception (0xc0000005)
    Fault Module: C:Program FilesSonyVegas Pro 10.0vegas100.exe
    Fault Address: 0x0000000000000000
    Fault Offset: 0x0000000000000000
    Fault Process Details
    Process Path: C:Program FilesSonyVegas Pro 10.0vegas100.exe
    Process Version: Version 10.0e (Build 738) 64-bit
    Process Description: Vegas Pro
    Process Image Date: 2011-06-29 (Wed Jun 29) 10:33:50
    ________________________________________________________________
    “The true test of a man, is what he does with power.” Plato
    Karl Reith replied 15 years, 1 month ago 2 Members · 2 Replies
  • Steve Rhoden
    August 19, 2011 at 9:16 am
    Uninstall Vegas completely, Delete all its folders, restart and
    do a fresh install with version 10.0e(Cow Leader)
    Film Maker
    Filmex Creative Media.
    1-876-832-4956
    https://filmex-creative-media.blogspot.com/
  • Karl Reith
    August 19, 2011 at 10:13 am
    Thanks for your reply Steve,
    I will give it a shot! Will let you know if it sorts it out!
    _________________________________________________________________
