Activity › Forums › VEGAS Pro › Sony Vegas freezing during render
  • Sony Vegas freezing during render
    Posted by Sonnie Lee on August 5, 2010 at 1:22 am
    Everytime I try to render my video, it keeps on stopping at 29% and when I look at the time left , it`s 0:00 , but the render time keeps on going. Please help.
    Peter Fison replied 16 years, 1 month ago 3 Members · 2 Replies
  • Frederic Baumann
    August 5, 2010 at 9:50 am
    Can you give more details ?
    – which output format? whith which settings?
    – which format for your footages?
  • Peter Fison
    August 7, 2010 at 4:03 pm
    I’ve also had this problem… I split a Theatre Play into 8 different .veg projects, one for each of the Scenes in the Play. All of them except one rendered fine after editing – imported footage was all AVCHD / MP4 and rendering output was always m2v (HDV 1080-24p).
    Effects applied included brightness/contrast as mentioned above, cropping, motion tracking, and Sony Rays effect.
    I noticed the ‘freeze’ happened regardless of where in the project I set the render region. If the render region was small enough, it rendered fine. If it went over a critical size (about 604MB) it would freeze. In the end I had to split the scene down into 7 sections of 604MB, render them individually, and then stitch them together again in a new project.
    My system is 64 bit, Windows 7, quad core processor, 8MB RAM, using Sony Vegas 9.0e.
