Activity › Forums › VEGAS Pro › Sony vegas flickering bug!
  • Sony vegas flickering bug!
    Posted by Danny Lines on September 19, 2014 at 9:38 pm
    So for some reason not much in sony vegas is working properly. When i add twixtor, set keyframes become bugged and their timings get distorted, e.g. if i add a keyframe for the video to zoom in zoom out and zoom back in all 1 second apart from each other, nothing will happen for the first 2 where it will then do all the keyframes and slowly zoom back out.
    I get the flickering bug which is the most annoying when i overlap clips to fade them out, i turned off gpu acceleration, and it worked, but when i add keyframes to clips the flcikering starts again. Any help here guys, incredible frustrating for a content creator!
    Just tried to fade one in and out over the other slower (over about 5 seconds) and the whole of sony vegas instantly crashed :/
    Danny Lines replied 12 years ago 3 Members · 5 Replies
  • Bob Peterson
    September 20, 2014 at 1:30 pm
    You probably need to provide details about your computer before thinking that Vegas has a bug. It sounds like your computer is underpowered which would cause Vegas to lag the video in preview mode.
  • John Bolton
    September 20, 2014 at 2:03 pm
    Hi Danny… Is this before or after you have rendered you notice these problems?
  • Danny Lines
    September 20, 2014 at 6:38 pm
    r9 290
    i5 4670k
    8gb ram
    2x 1Tb Hdd
    750 PSU
    z87 hd3 mobo
    I know 750w is more than enough, thank you very much.
  • Bob Peterson
    September 21, 2014 at 1:15 pm
    750w? An i5 with 8gb of ram is a bit underpowered. I was not referring to the size of the power supply. I was asking about the computer’s speed.
  • Danny Lines
    September 21, 2014 at 3:29 pm
    2x4gb of ram is fine for a i5. I could use sony fine with 4gb of ram on my old computer!
