Activity Forums VEGAS Pro Sony Vegas Error Importing Downloaded File
  • Sony Vegas Error Importing Downloaded File
    Posted by Monica James on December 5, 2009 at 4:28 pm
    Hello,
    I have experienced a problem with importing video I have downloaded from YouTube using ‘YouTube Downloader HD’ program. I downloaded it as AVI HD (720p)
    I downloaded a video which I wanted to edit using Sony Vegas Pro 8,
    I tried to import it, it howed up in the ‘Explorer’ menu, but when I tried to drag it into the timeline it said this message
    ERROR – Sony Vegas Pro 8.0
    Version 8.0a (Build 179)
    Exception 0xC0000094 (integer divide by zero) IP:0x33A8CA19
    In Module ‘mcmp4plug.dll’ at Address 0x339A0000 + 0xECA19
    Thread: GUI ID=0xC4C Stack=0x18A000-0x190000
    Registers:
    EAX=00000000 CS=0023 EIP=33a8ca19 EFLGS=00210246
    EBX=0d78fc1c SS=002b ESP=0018a248 EBP=0d78fb40
    ECX=00000000 DS=002b ESI=00000002 FS=0053
    EDX=00000000 ES=002b EDI=00000000 GS=002b
    Bytes at CS:EIP:
    33A8CA19: F7 F1 8B 44 24 0C F7 F1 …D: 8B C2 33 D2 4F 79 4E EB ..3.OyN.
    Stack Dump:
    0018A248: 00000000
    0018A24C: 0D78FC1C 0D560000 + 22FC1C
    0018A250: 339B2785 339A0000 + 12785 (mcmp4plug.dll)
    0018A254: 00000002
    0018A258: 00000000
    0018A25C: 00000000
    0018A260: 00000000
    0018A264: 0D78FC18 0D560000 + 22FC18
    0018A268: 0D78FC1C 0D560000 + 22FC1C
    0018A26C: 00000000
    0018A270: 00000000
    0018A274: 0D78FB40 0D560000 + 22FB40
    0018A278: 0D78FB70 0D560000 + 22FB70
    0018A27C: 0018A6A8 00090000 + FA6A8
    0018A280: 00000000
    0018A284: 00000000
    > 0018A2A0: 77E0F871 77DF0000 + 1F871 (ntdll.dll)
    > 0018A2A4: 771C0816 771B0000 + 10816 (KERNELBASE.dll)
    > 0018A2B0: 771C0849 771B0000 + 10849 (KERNELBASE.dll)
    > 0018A300: 771E5EB0 771B0000 + 35EB0 (KERNELBASE.dll)
    > 0018A30C: 771C0849 771B0000 + 10849 (KERNELBASE.dll)
    > 0018A310: 76CD1184 76CC0000 + 11184 (kernel32.dll)
    > 0018A31C: 339B2F97 339A0000 + 12F97 (mcmp4plug.dll)
    > 0018A354: 339B2459 339A0000 + 12459 (mcmp4plug.dll)
    > 0018A390: 77E6041D 77DF0000 + 7041D (ntdll.dll)
    > 0018A39C: 016BFCC0 013E0000 + 2DFCC0 (vegas80k.dll)
    0018A3A0: 00000000
    0018A3A4: 00000000
    0018A3A8: FFFF0000
    0018A3AC: 00000000
    > 0018A3D0: 76CFC019 76CC0000 + 3C019 (kernel32.dll)
    > 0018A3F8: 00480000 00400000 + 80000 (vegas80.exe)
    > 0018A3FC: 00480000 00400000 + 80000 (vegas80.exe)
    0018A400: B4395810
    0018A404: 4047F6C8
    0018A408: 00000000
    0018A40C: 00000A11
    > 0018A410: 014563D3 013E0000 + 763D3 (vegas80k.dll)
    0018A414: 000003E8
    0018A418: 00000000
    0018A41C: 000003E8
    0018A420: 00000000
    > 0018A474: 0055005C 00400000 + 15005C (vegas80.exe)
    > 0018A478: 00650073 00400000 + 250073 (vegas80.exe)
    0018FFF0: 00000000
    0018FFF4: 0083C9AB 00400000 + 43C9AB (vegas80.exe)
    0018FFF8: 7EFDE000 7EFDE000 + 0
    0018FFFC: 00000000
    PLEASE HELP!! I have downloaded the full K-Lite codec pack too, it plays fine in windows media player.
    Joe Ibanez replied 16 years, 1 month ago 6 Members · 10 Replies
  • 10 Replies
  • Mike Kujbida
    December 5, 2009 at 7:11 pm
    Rule #1.
    Make sure you’re running the latest version of your software.
    Vegas Pro 8 is at 8.0c so download and install it and see if you still have problems.
    Rule #2.
    Never install a codec pack as they can install all kinds of garbage that you don’t need and can end harm doing more harm than good.
    Only download what you need to get the job done.
  • John Rofrano
    December 5, 2009 at 9:32 pm
    You also might want to transcode YouTube video into something easier to edit. Use a tool like Avidemux 2.5 to convert the video to MJPEG, Lagarith, Huffyuv, or some other easily editable format.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Norman Willis
    December 6, 2009 at 2:15 am
    When I reformatted my laptop (Vista 32 Business) I lost sound on some people’s DVD’s. I searched for the specific codec, but could not find it. In the end I installed the smallest K-lite codec pack, and chose ‘essentials only’ (four items, it said). I got sound back on the DVD’s, but did I probably also install some garbage? And how can I avoid this in the future?
    I use the laptop mostly for testing, and maybe making thumbnails and such, but I don’t want to install any garbage, if it can be avoided (because that is probably why I had to reformat my laptop to begin with).
    Thanks.
    Norman Willis
    http://www.nazareneisrael.org
  • John Rofrano
    December 6, 2009 at 3:00 am
    Of all the codec packs, the K-Lite pack is probably the best because it gives you levels of choice but I have never installed a codec pack. I just use GSpot or some other tool to tell me which codecs a file needs and then I download only those codecs and install them. It takes a little work but it keeps things cleaner.
    The problem is that each codec registers itself to handle certain encoding and the last one you install wins for that encoding. For example, you may have paid a lot of money for your NLE and it came with a high quality MJPEG codec. Then you install a codec pack and it registers a free low quality MJPEG codec which unregisters your original one in order to register itself. Now you when you render to MJPEG, some cheap quality codec is being used by your expensive NLE and all of a sudden you can’t figure out why your videos look bad.
    This is why it’s best to just install the codecs that you need, so that good codecs that you already have don’t get overlaid by bad ones.
    ~jr
  • Norman Willis
    December 6, 2009 at 4:25 am
    OK, so in the future I should use GSpot.
    For right now, would it correct any potential problems if I uninstall and then reinstall Vegas on my laptop?
    Norman Willis
  • Monica James
    December 6, 2009 at 8:49 am
    thank you so much, the problem seems to have fixed now. I reinstalled vegas and uninstalled the codecs i didnt need. Thanks 😀
  • John Rofrano
    December 6, 2009 at 3:32 pm
    If you installed the Basic K-Lite codec pack then you might be OK. It only installs the Haali, MP4, & FLV directshow splitters. Some of the other packs install their own AVCHD filters which could conflict with Vegas but I don’t think anything in the Basic pack would. Re-installing Vegas might be a good idea just as a precaution. I’m not sure how the Basic pack fixed a DVD playback problem because you probably needed an AC3 codec or something which this pack doesn’t have (the DVD codecs are in the Standard pack).
    ~jr
  • Terry Esslinger
    December 6, 2009 at 7:51 pm
    Where are the codecs typically installed? Can you remove individual codecs, or do you need to remove an entire ‘pac’. If you remove an inferior MJPEG codec that was installed (for instance) over a better codec will the system reverdst to the better codec?
    Thanks for any knowledgeable answers.
  • John Rofrano
    December 7, 2009 at 3:01 am
    Get a copy of GSpot and go to System | List Codecs and Other Filters and you’ll see everything that is installed on your system. You can even right-click and unregister individual codecs and DirectX filters. Be careful and back up your system before you start playing with this.
    ~jr
  • Joe Ibanez
    July 26, 2010 at 7:43 pm
    I’m having the exact same problem that Levi-Jade had in the original post, and I’d downloaded Gspot but am a bit confused on what to do now. I’ve reinstalled Vegas but I don’t know how to disable codecs or even how to know which codecs to disable. Levi-Jade, if you read this, could you give me extremely detailed instructions on what you did to correct this issue? Thank you.
