Activity › Forums › VEGAS Pro › Sony Vegas crashes when using the glow effect
  • Sony Vegas crashes when using the glow effect
    Posted by Stephen Kennedy on May 10, 2012 at 1:48 am
    It crashes plenty other times too and I’m not happy with that at all. But, this is the most consistent one and I’m hoping that if I get to the bottom of it then the other crashes might at least slow down a bit.
    When I apply a glow effect and then close the effects window, it crashes every time. Like I said, it crashes when I apply other effects (or don’t apply them, sometimes it just crashes when I’m just scrubbing the timeline) but this is the only one that happens every time without fail. I tried saving before I closed the window and then I opened the project again. The glow effect was there and it was fine. I tested it by just opening the window again and closing it. Crash again. Here are the details of the problem.
    I’m using Vegas pro 11 64-bit with Windows 7 64-bit.
    Source
    Vegas Pro
    Summary
    Stopped working
    Date
    ‎5/‎9/‎2012 9:31 PM
    Status
    Report sent
    Description
    Stopped working
    Faulting Application Path: C:Program FilesSonyVegas Pro 11.0vegas110.exe
    Problem signature
    Problem Event Name: CLR20r3
    Problem Signature 01: vegas110.exe
    Problem Signature 02: 11.0.0.683
    Problem Signature 03: 4f967c0e
    Problem Signature 04: Sony.MediaSoftware.VideoEffectsUI
    Problem Signature 05: 11.0.0.683
    Problem Signature 06: 4f967ba2
    Problem Signature 07: 574
    Problem Signature 08: d
    Problem Signature 09: System.NullReferenceException
    OS Version: 6.1.7601.2.1.0.256.1
    Locale ID: 1033
    Extra information about the problem
    Bucket ID: 2950812120
    Stephen Crye replied 14 years, 4 months ago 5 Members · 13 Replies
  • 13 Replies
  • Mark Barton
    May 10, 2012 at 5:41 am
    I have no problems with the Sony glow effect, so maybe it is video driver related. I’m using the same build 683 of SVP 11. I have an Nvidia GTX 570 with the 301.24 drivers. I have the GPU option turned on under Tools/Options/Video. Check the following directory for the GPU and other logs to see if any additional error information was logged.
    “C:Users…AppDataLocalSonyVegas Pro11.0gpu_video_x64.log”
  • Stephen Kennedy
    May 10, 2012 at 4:22 pm
    This is the full contents of that log. The important part seems to be at the very end but I don’t know if some of the other information could tell you something about my system that could be helpful.
    INFO 2012-05-09 23:59:35 *** Start of GPU-accelerated video processing log ***
    INFO 2012-05-09 23:59:35 Vegas Pro 11.0
    INFO 2012-05-09 23:59:35 Version 11.0 (Build 683) 64-bit
    INFO 2012-05-09 23:59:35 OpenCL_Initialize
    INFO 2012-05-09 23:59:35 Platforms: 1
    INFO 2012-05-09 23:59:35 Platform: 0
    INFO 2012-05-09 23:59:35 Vendor: Advanced Micro Devices, Inc.
    INFO 2012-05-09 23:59:35 Name: AMD Accelerated Parallel Processing
    INFO 2012-05-09 23:59:35 Version: OpenCL 1.1 AMD-APP (898.1)
    INFO 2012-05-09 23:59:35 Profile: FULL_PROFILE
    INFO 2012-05-09 23:59:35 Extensions: cl_khr_icd cl_amd_event_callback cl_amd_offline_devices cl_khr_d3d10_sharing
    INFO 2012-05-09 23:59:35 Devices: 2
    INFO 2012-05-09 23:59:35 Device: 0
    INFO 2012-05-09 23:59:35 Type: GPU
    INFO 2012-05-09 23:59:35 Name: Juniper
    INFO 2012-05-09 23:59:35 C version: OpenCL C 1.1
    INFO 2012-05-09 23:59:35 Extensions: cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_gl_sharing cl_ext_atomic_counters_32 cl_amd_device_attribute_query cl_amd_vec3 cl_amd_printf cl_amd_media_ops cl_amd_popcnt cl_khr_d3d10_sharing cl_amd_meminfo
    INFO 2012-05-09 23:59:35 Driver version: CAL 1.4.1703 (VM)
    INFO 2012-05-09 23:59:35 Available: Yes
    INFO 2012-05-09 23:59:35 Compiler: Yes
    INFO 2012-05-09 23:59:35 Image support: Yes
    INFO 2012-05-09 23:59:35 Unified memory: No
    INFO 2012-05-09 23:59:35 Vendor ID: 4098
    INFO 2012-05-09 23:59:35 Compute units: 10
    INFO 2012-05-09 23:59:35 Work dimensions: 3
    INFO 2012-05-09 23:59:35 Clock Frequency: 850
    INFO 2012-05-09 23:59:35 Image reads: 128
    INFO 2012-05-09 23:59:35 Image writes: 8
    INFO 2012-05-09 23:59:35 Samplers: 16
    INFO 2012-05-09 23:59:35 Workgroup size: 256
    INFO 2012-05-09 23:59:35 Image width: 8192
    INFO 2012-05-09 23:59:35 Image height: 8192
    INFO 2012-05-09 23:59:35 Parameter size: 1024
    INFO 2012-05-09 23:59:35 Maximum alloc: 536870912
    INFO 2012-05-09 23:59:35 Memory size: 1073741824
    INFO 2012-05-09 23:59:35 Local memory: 32768
    INFO 2012-05-09 23:59:35 Work item sizes: 256, 256, 256
    INFO 2012-05-09 23:59:35 Out of order Q: No
    INFO 2012-05-09 23:59:35 Profiling Q: Yes
    INFO 2012-05-09 23:59:35 Device is compatible.
    INFO 2012-05-09 23:59:35 Device: 1
    INFO 2012-05-09 23:59:35 Type: CPU
    INFO 2012-05-09 23:59:35 Vendor: AuthenticAMD
    INFO 2012-05-09 23:59:35 Name: AMD Phenom(tm) II X4 955 Processor
    INFO 2012-05-09 23:59:35 Extensions: cl_khr_fp64 cl_amd_fp64 cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_byte_addressable_store cl_khr_gl_sharing cl_ext_device_fission cl_amd_device_attribute_query cl_amd_vec3 cl_amd_printf cl_amd_media_ops cl_amd_popcnt cl_khr_d3d10_sharing
    INFO 2012-05-09 23:59:35 Driver version: 2.0
    INFO 2012-05-09 23:59:35 Unified memory: Yes
    INFO 2012-05-09 23:59:35 Compute units: 4
    INFO 2012-05-09 23:59:35 Clock Frequency: 3192
    INFO 2012-05-09 23:59:35 Workgroup size: 1024
    INFO 2012-05-09 23:59:35 Parameter size: 4096
    INFO 2012-05-09 23:59:35 Maximum alloc: 2147483648
    INFO 2012-05-09 23:59:35 Memory size: 4294238208
    INFO 2012-05-09 23:59:35 Work item sizes: 1024, 1024, 1024
    WARN 2012-05-09 23:59:35 Device type not supported
    WARN 2012-05-09 23:59:35 Device is not compatible.
    Are those last few messages talking about my video device? It’s an ATI Radeon HD 5700 series with version 8.950.0.0 drivers. According to the system requirements for the program that should be fine shouldn’t it?
  • Steve Rhoden
    May 10, 2012 at 5:48 pm
    Disable your GPU and see if the process still crashes Vegas.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    1-876-832-4956
  • Stephen Kennedy
    May 10, 2012 at 5:54 pm
    Do you mean turn disable GPU accelerated processing off? Because, it’s already off.
  • Stephen Kennedy
    May 10, 2012 at 6:53 pm
    It happened when it was on also. There seems to be no difference.
  • Mark Barton
    May 11, 2012 at 8:23 am
    I don’t have an AMD video card but according to Sony, you should have Catalyst driver 11.7 and I found 12.4 on the AMD site. It could be we are just reading different version numbers (Catalyst vs the driver).
    https://www.sonycreativesoftware.com/vegaspro/gpuacceleration
    AMD/ATI
    Requires an OpenCL-enabled GPU and Catalyst driver 11.7 or later with a Radeon HD 57xx or higher GPU. If using a FirePro GPU, FirePro unified driver 8.85 or later is required.
    The release notes for Catalyst 12.4 states you have an older driver:
    The AMD Catalyst software suite 12.4 contains the following:
    AMD display driver version 8.961
    HydraVision™ for Windows Vista® and Windows® 7
    Southbridge/IXP Driver
    AMD Catalyst Control Center version 8.961 / AMD Vision Engine Control Center version 8.961
    https://support.amd.com/us/gpudownload/windows/Pages/radeonaiw_vista64.aspx?type=2.4.1&product=2.4.1.3.43&lang=us&rev=&ostype=Windows%207%20-%2064-Bit%20Edition
  • Stephen Kennedy
    May 11, 2012 at 12:19 pm
    I actually have 12.3, but like I said I have GPU acceleration turned off. Also, I should mention that I’ve been using the glow effect in combination with masking. When I just use the effect by itself it doesn’t seem to cause a crash. But rather than focus on the effect I just want to know why this program is so unstable in general. If this keeps up I may just go back to 9 or 10.
    I’ll upgrade to 12.4 and try turning on gpu acceleration again.
  • Stephen Kennedy
    May 11, 2012 at 1:18 pm
    Okay, I’ve upgraded from 12.3 to 12.4. I opened the project, opened the effects window for the clip then closed it, and the program crashed. I tried it both with GPU acceleration on and off. The only difference was that when it was off, it didn’t crash the first time I closed the window. But, it was just a fluke. I tried it again just to be sure, and it crashed the second time.
  • Steve Rhoden
    May 11, 2012 at 4:28 pm
    Ahhhhhh, what can i say Stephen, another Vegas 11 bug that
    needs clearing up it seems.
    Steve Rhoden
    (Cow Leader)
    1-876-832-4956
  • Stephen Kennedy
    May 11, 2012 at 4:59 pm
    Well, thanks for the effort. I’ve been doing some more intense testing of this specific crash and it’s less consistent than I thought it was, but it’s still more likely to crash than not. I keep feeling like there’s some underlying reason for all these crashes, glow effect or otherwise, that is easily fixed.
    My overall crash frequency did not go down after the latest update. If anything, it increased. As I understand, I’m not the only one with this problem. Vegas is a great program but something about this version is just off. Even if this specific crash is dealt with in the next update, there are still plenty of others. I often edit for contests in which speed editing is important and I can’t afford all of these crashes. If the next update doesn’t fix it I’m going to have to go back to 9.0 which is the last version I know works (I was slow and skipped 10. No idea how stable it is). I don’t want to do that because I really love the new features when they work. How often would you say updates come around?
