Activity Forums VEGAS Pro Sony Vegas Crashes When I Open AVCHD From PVR
  • Sony Vegas Crashes When I Open AVCHD From PVR
    Posted by Charlie Crepps on January 22, 2012 at 10:07 pm
    I record In avc hd and the qaulity is just fine. But it crashes (sometimes) When i open The AVCHD video but when i try to render with my settings or try to play back the video vegas crashes ideas?
    Adrian Fox replied 14 years, 7 months ago 3 Members · 2 Replies
  • Nigel O’neill
    January 24, 2012 at 3:13 am
    Charlie
    I may help to know what PVR you are using. It is also worth noting that some camera manufacturers tinker with the standard implementation of AVCHD, meaning that your AVCHD is not what the editing software is expecting, hence the crashes.
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 10e (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • Adrian Fox
    January 24, 2012 at 6:30 pm
    Like Nigel said, it would be helpful to know what PVR you are using, I myself use a Hauppauge HDPVR and I know that there are problems with using the files in Vegas, if by any chance you are also using the Hauppauge, then I would recommend using the Playstation 3 option to record your videos (m2ts format), I have always used it and never had any problems.
