Activity › Forums › VEGAS Pro › Sony Vegas: Cookie Cutter Problem
  • Sony Vegas: Cookie Cutter Problem
    Posted by Lucy Scarlet on February 25, 2013 at 1:13 am
    I just got sony vegas 11 today, and I don’t know if this happens to everyone or just on my vegas. I add the effect ‘cookie cutter’ to a clip and just choose the rectangle as my shape and it looks normal, but then i add the effect ‘soft contrast’ over it and it ends up looking like this:
    the shape of the rectangle is clearly there but then the rest of the picture is also showing. any idea how i can get rid of the rest of the picture?
    Graham Bernard replied 13 years, 7 months ago 2 Members · 1 Reply
  • Graham Bernard
    February 25, 2013 at 5:26 am
    [Erza Scarlet] ” but then i add the effect ‘soft contrast’ over it and it ends up looking like this:”
    I’ve tried to repro what I think you have got, by moving the the Pre- and Post- links in the FX chain, but I can’t repro what you have. It’s that “bleed” through of the CC edge – yes? It could be something as straightforward as using Soft Contrast, which has a variable rectangular Vignetting that, in itself, has a Transparent element that COULD be aligning itself with that of the rectangular “border” of the Cookie Cutter?
    Also, what Build Number of VP11 are you on? One of the Builds corrected the following: [This from the Official SONY White Paper on VP11]
    “Fixed an issue with Defocus, Glint, Rays, Soft Contrast, and Starburst when used with images with alpha channel or transparency.”
    In any event, I really like what you HAVE got! It looks quite stunning!
    Grazie
