Activity Forums VEGAS Pro Sony Vegas blocky videos (After Render)
  • Sony Vegas blocky videos (After Render)
    Posted by Tristan Burns on July 6, 2013 at 3:13 pm
    I record videos with my HD pvr 2, my raw video looks great, but after I render in mp4, I get these “blocks” or pixelation on my videos. Here is an example:
    Anybody know the issue?
    Tristan Burns replied 13 years, 2 months ago 4 Members · 5 Replies
  • Josh Bullen
    July 6, 2013 at 5:21 pm
    I’ve too had this issue. I rendered in 1080p and the majority of the video is fine, but is broken up with intermittent periods of ‘blocky video’. Source material is fine and is definitely a post-render issue.
    Hope someone can help myself and Tristan soon.
  • Tristan Burns
    July 6, 2013 at 7:43 pm
    Thanks for the response! Glad to hear I’m not the only one with this problem.
  • Dave Weldy
    July 6, 2013 at 11:27 pm
    have the same issue here
  • Stephen Mann
    July 7, 2013 at 3:04 am
    Your PVR is recording in a very compressed MPEG2 format, then you are recompressing it into MP4. MPEG does not do well with large solids.
    You might try using the deblocking filter. From the help file: “AVC encoding divides a video frame into smaller sections called macroblocks and compresses each block separately. During decompression, edges between the blocks can sometimes be seen. A deblocking filter smoothes the edges between blocks to make them less visible.
    When encoding to a low bit rate, select this check box to set a flag that allows the decoder to apply a filter to reduce the appearance of blocking in your video.
    When encoding to a high bit rate, clear the check box. Deblocking high-bit rate video can produce artifacts.”
    Also, what “quality” or speed setting is your PVR set to? Some are 2,4,6-hour “modes”. Each in progressively higher compression and worse for editing. Not that a PVR file is good for editing in the first place.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Tristan Burns
    July 8, 2013 at 1:13 am
    Thanks for the help! But one question.. what is considered a high bit rate when encoding? For example if I use a variable bit rate of 14,000,000 max.. and 10,000,000 average..Is that high?
