Activity Forums VEGAS Pro sony vegas “blink effect”
  • Joe White
    October 10, 2010 at 9:21 pm
    How are you getting the footage? What are you rendering out of Vegas as?
  • John Rofrano
    October 11, 2010 at 12:56 am
    My guess is that’s FRAPS footage. Try converting it to MJPEG or some other format that Vegas can edit and render correctly.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Ethan Mounfield
    October 12, 2010 at 6:53 pm
    I’m recording with a HD PVR, the file type is .m2ts, but if I convert it takes ages and makes it 30fps instead of 60fps
  • John Rofrano
    October 16, 2010 at 12:14 am
    [Ethan Mounfield] “I’m recording with a HD PVR, the file type is .m2ts, but if I convert it takes ages and makes it 30fps instead of 60fps”
    Try recording to .TS files at 30fps next time. These should edit fine in Vegas.
    ~jr
